MemoryError: memory allocation failed, allocating 1584 bytes
mschulz
Post by mschulz » Wed Sep 16, 2015 12:48 pm
I have a new Problem, that I do notunderstand.
I get the following error, when I write one more code line, but I think the line is ok. It is equal witch line I write:
  File "main.py", line 23, in <module>
Micro Python v1.3.10 on 2015-02-13; PYBv1.0 with STM32F405RG
What can I do to solve this error?
Thank you!
danicampora
Re: MemoryError: memory allocation failed, allocating 1584 bytes
Post by danicampora » Wed Sep 16, 2015 12:54 pm
Sharing the piece of code that is causing the exception might be useful, otherwise it is difficult to help you...
mschulz
Post by mschulz » Wed Sep 16, 2015 1:17 pm
This code runs, but when I uncommand the last line I get the error.
                pos[0]=abs(F_KE_Rv/F_KE_Rh) # verhältnis Vorn zu Hinten
                if self.__pos_alt[0]>=0 and self.__pos_alt[2]>=0 and self.__pos_alt[4]>=0:
                    pos[0]=(self.__pos_alt[0]+self.__pos_alt[2]+self.__pos_alt[4]+pos[0])/4
                elif self.__pos_alt[0]>=0 and self.__pos_alt[2]>=0:
                    pos[0]=(self.__pos_alt[0]+self.__pos_alt[2]+pos[0])/3
                #elif self.__pos_alt[0]>=0:
                #   pos[0]=(self.__pos_alt[0]+pos[0])/2
Post by pythoncoder » Thu Sep 17, 2015 6:23 am
The Pyboard has about 100KB of RAM for heap storage and it looks like your program is using all of it. Floating point maths uses the heap and my guess is that the line of maths you've commented out is trying to allocate memory which is unavailable. In other words the problem isn't with the line of code but with the overall design.
To answer the question of why all the memory is being used or to suggest a fix I think we'd need to see the entire program. Are your arrays large? If so, are they arrays or lists? (Arrays are more memory-efficient).
