How many data can the transmit method send?
manos
Post by manos » Fri Nov 27, 2020 8:04 am
Hey,
Being a noob in Micropython and the Xbee 3 RF Zigbee module I have, I have faced the following problem:
While trying to transmit wirelessly some data/message from one xbee to another one (using the xbee.transmit method), I noticed that depending on the size of the message, an error might be raised. If I recall correctly it was an error of type EAGAIN.
My guess that the fault was the size of the message, is based on the fact that if I send a long string (like a whole sentence) I get the error, whilst if I send a simple "hello" the message is transmitted successfully!
So, is there a way to know what is the max size of the message-payload that I can pass as an argument in the xbee.transmit() method?
Thanks in advance!
Re: How many data can the transmit method send?
Post by jimmo » Sun Jan 10, 2021 11:18 pm
Unfortunate Digi have never released the code for their MicroPython fork so very little is known about internal details like this... (This is a real shame because these modules are very useful). You might have more luck posting on the Digi forum -- https://www.digi.com/support/forum/
In general though, this is fairly typical of a low-level API for transmitting data -- there will be a fixed transmit buffer size. You can probably try and figure this out by sending increasingly large messages until it fails.
