ESP8266 WiFi client
enzo
ESP8266 WiFi client
Post by enzo » Wed Dec 30, 2020 10:26 pm
Hi everybody,
please, can anyone explain why this code:
def connectToWifi(SSID, PW):
    wlan.active(True)
    if not wlan.isconnected():
        print("Connecting to network...")
        wlan.connect(SSID, PW)
        while not wlan.isconnected():
            pass
    print('Connection successful')
    mac = ubinascii.hexlify(network.WLAN().config('mac'),':').decode()
    return(wlan.ifconfig())
client_config = connectToWifi(SSID, PW)
print(client_config)
sometimes outputs this messages:
>>> bcn_timout,ap_probe_send_start
ap_probe_send over, rest wifi status to disassoc
state: 5 -> 0 (1)
rm 0
pm close 7
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
connected with synwiuninet, channel 6
dhcp client start...
ip:10.0.0.191,mask:255.255.255.0,gw:10.0.0.2
pm open,type:2 0
Please note that other devices (smartphones) connected to the same network works fine.
Is there anywhere a list of these MicroPython wifi related warning/errors?
Thanks.
Re: ESP8266 WiFi client
Post by pythoncoder » Thu Dec 31, 2020 6:51 am
This guide might help.
bitninja
Post by bitninja » Thu Dec 31, 2020 7:32 pm
Those are normal ESP debug messages. Add...
import esp
esp.osdebug(None)
And the messages will be suppressed.
Post by pythoncoder » Sat Jan 02, 2021 5:51 am
Yes, but the fact that they are spontaneously being emitted suggests that something untoward is happening.
bitninja
Post by bitninja » Sat Jan 02, 2021 7:19 am
I don't believe so.
I have always seen these messages when working with the ESP8266. By default the latest image (esp8266-20200911-v1.13.bin) seems to be setup to have the Access Point enabled and the debug messages disabled.
I just tested this with a freshly burned Wemos D1 Mini...
paste mode; Ctrl-C to cancel, Ctrl-D to finish
=== import network
=== wlan = network.WLAN(network.STA_IF)
=== wlan.active(True)
=== wlan.connect('testap', 'password')
#5 ets_task(4020f560, 28, 3fff9ed8, 10)
>>> wlan.disconnect()
>>> import esp
>>> esp.osdebug(0)
>>> wlan.disconnect()
state: 5 -> 0 (0)
rm 0
>>> scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
connected with testap, channel 11
ip:10.0.2.10,mask:255.255.255.0,gw:10.0.2.2
While
esp.osdebug(None)
seems to be the default now, I do not believe it always has been. In any case, I usually leave
esp.osdebug(0)
enabled until I am ready to release the code.
Post by pythoncoder » Sun Jan 03, 2021 10:02 am
@bitninja I agree that debug messages are emitted after events like connect and disconnect. My reading of @enzo's message was that, having established the connection, his board then subsequently emitted these messages on occasion with no obvious cause.
This could be evidence of a problem. In my view it's more likely that it results from occasional WiFi outages with the ESP8266 reconnecting: this does occur, about once an hour here.
bitninja
Post by bitninja » Sun Jan 03, 2021 3:35 pm
Ah, I see what you mean.
Yes, that would a problem if enzo is not expecting the disconnect/connects.
enzo
Post by enzo » Sun Jan 03, 2021 3:54 pm
That isn't an issue if the messages don't interfere with the software, i.e. I can ignore them in production.
enzo
Post by enzo » Tue Jan 12, 2021 7:57 pm
Ok, now I disabled the Micropython debugger and don't see all those messages anymore.
Only
#6 ets_task(4020ee60, 28, 3fff8e18, 10)
still appears but that's not an issue (however I'd like to be able to understand what is tells!).
But can anyone please suggest me why this code:
    print(ubinascii.hexlify(network.WLAN().config('mac'),':').decode())
    client = network.WLAN(network.STA_IF)
    client.active(True)
    print(client.scan())
    if not client.isconnected():
        client.connect(SSID, PW)
        while not client.isconnected():
            pass
    return(client)
client = connectToWifi("homeSSID", "homepw")
print(client.ifconfig())
print(client.status())
works perfectly on a ESP8266 node MCU an gets stuck in the
row in other 3 identical boards?
The boot file is the same in all of them:
import esp
esp.osdebug(None)
import uos, machine, gc
gc.collect()
All of them work fine when configured as AP.
All the boards correctly see the existing networks when they
client.scan()
so the hardware is ok.
I deleted and re-inserted all the MAC addresses in my router's ACL to exclude problem on that side.
I'm going nut on this, I re-flashed Micropython on all the boards just to be sure it is ok but nothing changes on any board.
Please, any idea about this?
Post by Roberthh » Tue Jan 12, 2021 8:43 pm
Two notes. I do not recommend a busy wait in the loop for wait connected. better add a small delay, like:
    client.active(True)
            time.sleep_ms(100)
    return(client)
Since a while I have the issue with the ESP8266 that they only connect to the WiFi STA after a power cycle. Pushing reset is not sufficient. I cannot exactly tell the time or version at which that started, but it could be the change from v1.12 to v1.13.
