Hello, I need some help with my coding. I am using NodeMCU ESP32 to send data to blynk apps using virtual pins. I can already connect to wifi and blynk but the data cannot be displayed in the app. I am trying to connect to blynk server. I programme using micropython. Any thoughts on improving the code?
import usocket as socket
except:
import socket
import blynklib
from machine import Pin, ADC
from time import sleep
import utime as time
import esp
esp.osdebug(None)
import gc
gc.collect()
WIFI_SSID = ''
WIFI_PASS = ''
BLYNK_AUTH = ''
#internet connection
print("Connecting to WiFi...")
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect(WIFI_SSID, WIFI_PASS)
print (station.isconnected()) # False = not connected , by right it should get TRUE
while not station.isconnected(): #if the station is not connected
time.sleep(1)
print('WiFi connect retry ...')
print('IP: ', station.ifconfig())
# connect to blynk apps
print("Connecting to Blynk...")
blynk = blynklib.Blynk(BLYNK_AUTH)
# define input pin
port = ADC(Pin(34)) # pin for steps
port.atten(ADC.ATTN_11DB)
# register handler for virtual pin V10 reading
@blynk.handle_event('read V10')
def stepcounter_handler (pin):
stepcount = 0
print (stepcount)
print('ready to read the value')
port_value = port.read()
sleep(1)
if port_value >= 2050:
print (port_value)
stepcount += 1
print ('Number of steps:',stepcount)
print('Read event on pin {}'.format(pin))
blynk.virtual_write(pin, stepcount)
print (port_value)
print ('no steps')
# infinite loop that waits for event
#...connect to blynk cloud...###
@blynk.handle_event("connect")
def connect_handler():
print("[CONNECT_EVENT]")
print('Sleeping 2 sec in connect handler...')
time.sleep(2)
blynk.disconnect()
@blynk.handle_event("disconnect")
def disconnect_handler():
print("[DISCONNECT_EVENT]")
print('Sleeping 4 sec in disconnect handler...')
time.sleep(4)
#...connect to blynk apps...###
@blynk.handle_event('internal_acon')
def app_connect_handler(*args):
print("[APP_CONNECT_EVENT]")
@blynk.handle_event('internal_adis')
def app_disconnect_handler(*args):
print("[APP_DISCONNECT_EVENT]")
blynk.run()
