Why hard reset WiFi connection typically fail?
Divergentti
Post by Divergentti » Thu Jan 14, 2021 3:57 pm
I noticed that after every hard reset WiFi connection wont establish correctly, but after soft reboot WiFi works fine. See video. What might cause this? I have it in all my setups, but I have not yet understood why this happens.
ESP32 either SMD, DevBoard, esp32-idf4-20200902-v1.13.bin
Video https://youtu.be/TezDU61fiCw
Code https://github.com/divergentti/airquali ... en/main.py
Network part of the code:
class ConnectWiFi:
    """ This class creates network object for WiFi-connection. SSID may be defined in the parameters.py or
    user may input a password, which is tried to WiFi APs within range. """
    def __init__(self):
        #  Check if we are already connected
        self.ip_address = None
        self.wifi_strenth = None
        self.timeset = False
        self.webrepl_started = False
        self.searh_list = []
        self.ssid_list = []
        self.mqttclient = None
        if network.WLAN(network.STA_IF).config('essid') != '':
            display.row_by_row_text("Connected to network %s" % network.WLAN(network.STA_IF).config('essid'), 'fuschia')
            self.use_ssid = network.WLAN(network.STA_IF).config('essid')
            display.row_by_row_text(('IP-address: %s' % network.WLAN(network.STA_IF).ifconfig()[0]), 'fuschia')
            self.ip_address = network.WLAN(network.STA_IF).ifconfig()[0]
            display.row_by_row_text("WiFi-signal strength %s" % (network.WLAN(network.STA_IF).status('rssi')), 'fuschia')
            self.wifi_strenth = network.WLAN(network.STA_IF).status('rssi')
            self.network_connected = True
            # resolve is essid in the predefined networks presented in parameters.py
            if self.use_ssid == SSID1:
                self.use_password = PASSWORD1
                self.predefined = True
            elif self.use_ssid == SSID2:
                self.use_password = PASSWORD2
            # We are not connected, check if SSID1 or SSID2 is predefined
            if (SSID1 is not None) or (SSID2 is not None):
                self.predefined = False
            self.password = None
            self.use_password = None    # Password may be from parameters.py or from user input
            self.use_ssid = None   # SSID to be used will be decided later even it is in the parameters.py
            self.network_connected = False
            self.search_wifi_networks()
    def start_webrepl(self):
        if self.webrepl_started is False:
            if WEBREPL_PASSWORD is not None:
                    webrepl.start(password=WEBREPL_PASSWORD)
                    self.webrepl_started = True
                except OSError:
                    pass
                    webrepl.start()
                except OSError as e:
                    print("WebREPL do not start. Error %s" % e)
                    display.row_by_row_text("WebREPL do not start. Error %s" % e, 'red')
                    return False
    def set_time(self):
        if self.timeset is False:
                ntptime.settime()
                self.timeset = True
                print("No time from NTP server %s! Error %s" % (NTPSERVER, e))
                display.row_by_row_text("No time from NTP server %s! Error %s" % (NTPSERVER, e), 'red')
                self.timeset = True
                return False
            print("Time: %s " % str(utime.localtime(utime.time())))
            display.row_by_row_text("Time: %s " % str(utime.localtime(utime.time())), 'white')
    def search_wifi_networks(self):
        # Begin with adapter reset
        network.WLAN(network.STA_IF).active(False)
        utime.sleep(1)
        network.WLAN(network.STA_IF).active(True)
        utime.sleep(2)
        if DHCP_NAME is not None:
            network.WLAN(network.STA_IF).config(dhcp_hostname=DHCP_NAME)
        if NTPSERVER is not None:
            ntptime.host = NTPSERVER
        display.row_by_row_text("Check what hotspots we see", 'white')
            # Generate list of WiFi hotspots in range
            self.ssid_list = network.WLAN(network.STA_IF).scan()
            utime.sleep(3)
        except self.ssid_list == []:
            print("No WiFi-networks within range!")
            display.row_by_row_text("No WiFi-networks within range!", 'red')
            utime.sleep(10)
        except OSError:
            return False
        if len(self.ssid_list) > 0:
            display.row_by_row_text("Found following hotspots:", 'white')
            for i in self.ssid_list:
                display.row_by_row_text(i[0].decode(), 'white')
        if self.predefined is True:
            #  Network to be connected is in the parameters.py. Check if SSID1 or SSID2 is in the list
            print("Checking if paramaters.py networks are in the list...")
            display.row_by_row_text("Checking predefined networks...", 'white')
                self.searh_list = [item for item in self.ssid_list if item[0].decode() == SSID1 or
                                   item[0].decode() == SSID2]
            except ValueError:
                # SSDI not found within signal range
                print("Parameters.py SSIDs not found in the signal range!")
                display.row_by_row_text("Parameters.py SSIDs not found in the signal range!", 'red')
                utime.sleep(10)
                return False
            # If both are found, select one which has highest stregth
            if len(self.searh_list) == 2:
                #  third from end of list is rssi
                if self.searh_list[0][-3] > self.searh_list[1][-3]:
                    self.use_ssid = self.searh_list[0][0].decode()
                    display.row_by_row_text("Using hotspot: %s" % self.use_ssid, 'yellow')
                    self.use_ssid = self.searh_list[1][0].decode()
                # only 1 in the list
        if self.predefined is False:
            #  Networks not defined in the parameters.py, let's try password to any WiFi order by signal strength
            #  Tries empty password too
            #  ToDo: rebuild, ask user input which hotspot we want to connect!
            self.ssid_list.sort(key=lambda x: [x][-3])
            if len(self.ssid_list) == 1:
                self.use_ssid = self.ssid_list[0][0].decode()
            elif len(self.ssid_list) > 1:
                z = 0
                while (network.WLAN(network.STA_IF).ifconfig()[0] == '0.0.0.0') and (z <= len(self.ssid_list)) and \
                        (self.network_connected is False):
                    self.use_ssid = self.ssid_list[z][0].decode()
                    z = +1
    def connect_to_network(self):
        #  We know which network we should connect to, but shall we connect?
        print("Connecting to AP %s ..." % self.use_ssid)
        display.row_by_row_text("Connecting to AP %s ..." % self.use_ssid, 'white')
            network.WLAN(network.STA_IF).connect(self.use_ssid, self.use_password)
            utime.sleep(5)
        except network.WLAN(network.STA_IF).ifconfig()[0] == '0.0.0.0':
            print("No IP address!")
            display.row_by_row_text("No IP address!", 'red')
            utime.sleep(10)
            return False
        except OSError:
            pass
        finally:
            if network.WLAN(network.STA_IF).ifconfig()[0] != '0.0.0.0':
                self.set_time()
                self.start_webrepl()
                                        'white')
                display.row_by_row_text(('IP-address: %s' % network.WLAN(network.STA_IF).ifconfig()[0]), 'white')
                                        'white')
                return True
                display.row_by_row_text("No network connection! Soft rebooting in 10s...", 'red')
                utime.sleep(10)
                reset()
    async def update_status_loop(self):
            if self.network_connected is True:
                await asyncio.sleep(1)
    def mqtt_init(self):
        config['server'] = MQTT_SERVER
        config['ssid'] = self.use_ssid
        config['wifi_pw'] = self.use_password
        config['user'] = MQTT_USER
        config['password'] = MQTT_PASSWORD
        config['port'] = MQTT_PORT
        config['client_id'] = CLIENT_ID
        config['subs_cb'] = self.update_mqtt_status
        config['connect_coro'] = self.mqtt_subscribe
        # Communication object
        self.mqttclient = MQTTClient(config)
    async def mqtt_up_loop(self):
        #  This loop just keeps the mqtt connection up
        await self.mqtt_subscribe()
        n = 0
            await asyncio.sleep(5)
            print('mqtt-publish', n)
            await self.mqttclient.publish('result', '{}'.format(n), qos=1)
            n += 1
    async def mqtt_subscribe(self):
        # await self.mqttclient.subscribe(TOPIC_OUTDOOR, 0)
    def update_mqtt_status(self, topic, msg, retained):
        # print("Topic: %s, message %s" % (topic, msg))
        status = int(msg)
        if status == 1:
            print("daa")
        elif status == 0:
            print("kaa")
davef
Re: Why hard reset WiFi connection typically fail?
Post by davef » Thu Jan 14, 2021 6:59 pm
The only thing that I have come across is " that the WiFi connection persists across soft-reboots not a hard reset". Yours sounds like the opposite!
If you do a machine.reset(), say in boot, and let the program run automatically does it also behave like a a hard reset?
Divergentti
Post by Divergentti » Fri Jan 15, 2021 7:30 am
If i use:
from machine import reset_cause
# 0 = power on, 6 = hard reset, 1 = WDT reset, 5 = DEEP_SLEEP reset, 4 soft reset
print("Previous boot reason %s" % reset_cause())
If reason is 6 (hard reset), then I end up to the problem, but if reason is either 0 or 4 (=machine.reset), then all ok. Perhaps I have to find some other handle to the network layer but ip-address and add some delay or extra adapter reset to the code.
