Data format to pass "Date Time" (0x2A08) over BLE
Simpler1
Post by Simpler1 » Sun Jan 17, 2021 3:37 pm
I'm just getting started with setting up an ESP32-CAM as a BLE server (peripheral) and for one of the characteristics, I'd like to pass the current date/time as set on the device.
I see from the 16-bit UUID Numbers document, that UUID 0x2A08 is "Date Time", but I'm not sure what format the date/time should be when I enter it as data to the
BLE().gatt_write(handle, data)
command.
I've tried the output from:
utime.time()    # 664211220
machine.RTC().datetime()  # (2021, 1, 17, 6, 15, 5, 5, 986239)
nRF Connect recognizes the characteristic as a Date Time based on the UUID, but the value is not even close.
I've reviewed the documentation for bluetooth in MicroPython, but it doesn't specify.
I expect that I need to do some conversion to bytes or bytearray, but I'm not sure where I would find the documentation to describe what is expected?
Simpler1
Re: Data format to pass "Date Time" (0x2A08) over BLE
Post by Simpler1 » Sun Jan 17, 2021 8:58 pm
After hours of scouring the internet, I came across these two slides:
https://speakerdeck.com/ephread/bluetoo ... y?slide=21
https://speakerdeck.com/ephread/bluetoo ... y?slide=22
So now I know the format is:
             0 1  2     3   4    5      6
Description  Year Month Day Hour Minute Second
Minimum      1582 1     1   0    0      0
Maximum      9999 12    31  23   59     59
with the year being a uint16.
I can manually piece together what will produce today's date:
b'\xE5\x07\x01\x11\x0F\x05\x00'
The primary question now, is how do I programmatically convert the output from machine.RTC().datetime() to this?
And the second question (not necessary for this forum) is why is this not documented somewhere on the Bluetooth website?
Simpler1
Post by Simpler1 » Sun Jan 17, 2021 9:26 pm
Here's what I came up with. It doesn't look pretty, but seems to work:
def nowBytes():
    rtc = machine.RTC()
    timestamp = rtc.datetime()
    time_bytes = struct.pack("<h", timestamp[0]) + struct.pack("b", timestamp[1]) + struct.pack(
        "b", timestamp[2]) + struct.pack("b", timestamp[4]) + struct.pack("b", timestamp[5]) + struct.pack("b", timestamp[6])
    return time_bytes
Is there a more efficient way to do this?
Post by jimmo » Mon Jan 18, 2021 4:41 am
There used to be a really useful reference for this on bluetooth.com, but there are a few places that contain the same information. For example:
https://github.com/oesmith/gatt-xml/blo ... e_time.xml
So this is telling you that the field is uint16-uint8-uint8-uint8-uint8-uint8 as you've discovered.
I would definitely recommend using struct.pack but a simpler way to use it is:
time_bytes = struct.pack("<hbbbbb", timestamp[0], timestamp[1], timestamp[2], timestamp[4], timestamp[5], timestamp[6])
or even
time_bytes = struct.pack("<hbbbbb", timestamp[0:3] + timestamp[4:])
Simpler1
Post by Simpler1 » Mon Jan 18, 2021 1:50 pm
Thanks for the link and example jimmo. Perfect.
