SD card recognition after reinserting.
sim222
Post by sim222 » Mon Jan 25, 2021 1:50 am
I have posted it on the pyboard forum however, I haven't got the reply for this issue,
PLZ give the advice ~
Hi guys,
Thanks for your valuable posting!!
I have searched the article last a few days however, failed to find any proper answer regarding my problem.
My project is the data logger using pyboard which should receive three sensors and send it's data through serial port and save any data.
So I need to save the data into the sd card.
My simple cord worked well however, after ejecting and re-inserting the card I can't access the card anymore until the power-resetting even keyboard-reset(Ctrl-D) didn't work.
So tested the mount method uos.mount() / uos.umount() / os.mount() / os.umount()
From the test, I have got the conclusion that ejecting the card makes me not to access the card anymore.
1. before ejecting, I can mount and unmount freely and access the card any time I want.
2. After re-inserting, I can't use any method related the access sd card before power-reset.
Got this kind of message to access the card.
Is it impossible to access it without power-resetting?
I think this kind of issue would occur easily in the real world because of the vibration.
How can I deal with this issue regarding sd card?
>>> uos.mount(sd,'/sd')
OSError: [Errno 19] ENODEV
Here's my cord.
#simple SD recorder
#Logs the data from the accelerometer to a file n the SD card
import pyb,lcd160cr
from BMP280 import BMP280_I2C
lcd = lcd160cr.LCD160CR('X')
lcd.set_orient(lcd160cr.PORTRAIT)
lcd.set_pos(0, 0)
lcd.set_text_color(lcd.rgb(255, 0, 0), lcd.rgb(0, 0, 0))
lcd.set_font(1,0)
lcd.write('Hello MicroPython!\n')
lcd.erase()
accel=pyb.Accel()
blue=pyb.LED(4)
s=BMP280_I2C(2)
f.write('From accelerometer, time,x,y,z,temperature,pressure\n')
f.close()
blue.on()
blue.on()
lcd.erase()
lcd.set_pos(0,0)
f=open('test.log','a')
for n in range (5):
t=pyb.millis()
rv=s.read()
x,y,z=accel.filtered_xyz()
f.write('{},{},{},{},{},{}\n'.format(t,x,y,z,s.temperature,s.mbar))
print('{},{},{},{},{},{}\n'.format(t,x,y,z,s.temperature,s.mbar))
lcd.set_pos(0,n*25)
lcd.write('{},{},{},{}\n'.format(t,x,y,z))
lcd.set_pos(0,n*25+10)
lcd.write('{0:0.2f},{1:0.2f}\n'.format(s.temperature,s.mbar))
pyb.delay(500) # 500ms
f.close()
blue.off()
pyb.delay(500)
Re: SD card recognition after reinserting.
Post by pythoncoder » Tue Jan 26, 2021 6:33 am
The Pyboard does not support hot plugging of the SD card.
sim222
Post by sim222 » Mon Feb 01, 2021 6:36 am
oops...
Then, how can I handle it?
It should be the only hardware reset?
Is there any software solution for this issue?
Post by pythoncoder » Mon Feb 01, 2021 9:16 am
My understanding is that the SD card should only be removed or inserted when the power is down.
It is possible to run an external SD card using the official sdcard.py driver. In this case you can provide your own power control circuit allowing you to power down the external SD card for removal and re-insertion.
sim222
Post by sim222 » Tue Feb 02, 2021 12:48 am
Thanks for your idea!!
Ok. I will try it.
Best regards,
