Asyncio in uPython 1.14 has not "run"???
enzo
Post by enzo » Sun Feb 07, 2021 3:17 am
I just installed MicroPython 1.14 and trying to understand non-blocking tasks I ran this example code from MicroPython 1.14 documentation:
import uasyncio
async def blink(led, period_ms):
        led.on()
        await uasyncio.sleep_ms(5)
        led.off()
        await uasyncio.sleep_ms(period_ms)
async def main(led1, led2):
    uasyncio.create_task(blink(led1, 700))
    uasyncio.create_task(blink(led2, 400))
    await uasyncio.sleep_ms(10_000)
uasyncio.run(main(Pin(1), Pin(2)))
but got this error:
AttributeError: 'module' object has no attribute 'run'
Please, can anyone explain me what's wrong?
Thanks.
kevinkk525
Re: Asyncio in uPython 1.14 has not "run"???
Post by kevinkk525 » Sun Feb 07, 2021 6:00 am
Strange. What does this return?: "uasyncio.__version__"
Did you have an older micropython on that microcontroller before and possible the files for the old uasyncio? Because this new version of uasyncio was introduced in micropython 1.13.
Kevin Köck
Post by pythoncoder » Sun Feb 07, 2021 7:51 am
The code runs here on a Pyboard (just changing the pin ID's). I agree with @kevinkk525: I suspect you have old firmware. You need V1.13 or the latest V1.14. What do you see when the board boots up?
enzo
Post by enzo » Sun Feb 07, 2021 12:50 pm
MicroPython v1.14 on 2021-02-02; ESP module (1M) with ESP8266.
It seems the last release.
However I had a 1.13 but it issued the same problem. And the uasyncio gets imported without any problem.
"run" seems not present in its methods:
>>> import uasyncio
>>> dir(uasyncio)
['__class__', '__name__', '__path__', 'log', 'select', 'sleep', 'sleep_ms', 'time', 'ucollections', 'uerrno', 'utimeq', 'DEBUG', 'uasyncio', '_socket', 'core', 'set_debug', 'PollEventLoop', 'EventLoop', 'StreamReader', 'IORead', 'IOReadDone', 'StreamWriter', 'IOWrite', 'IOWriteDone', 'open_connection', 'start_server', 'type_gen', 'CancelledError', 'TimeoutError', 'SysCall1', 'SleepMs', 'StopLoop', 'SysCall', 'get_event_loop', 'cancel', 'TimeoutObj', 'wait_for_ms', 'wait_for', 'coroutine', 'ensure_future', 'Task']
Indeed no "run" method here!
enzo
Post by enzo » Sun Feb 07, 2021 12:52 pm
AttributeError: 'module' object has no attribute '__version__'
I flashed the 1.14 and just copied the example from MicroPython 1.14 reference.
kevinkk525
Post by kevinkk525 » Sun Feb 07, 2021 1:46 pm
Since you don't have __version__, you have an old uasyncio version from before micropython 1.13..
which board are you using? What did you have on your board previously? Did you erase the flash before flashing the 1.14 firmware?
If you didn't have any files before, we might have to check the 1.14 release firmware.
I only downloaded the daily build for esp32 and it has a correct uasyncio.
Kevin Köck
enzo
Post by enzo » Sun Feb 07, 2021 6:39 pm
I'm using an ESP8266 MCU (the most common one as I can see). I'm using these boards since more than an year and ALWAYS erase the flash memory before flashing a new firmware.
In this board I had a stable 1.13 for months and all was ok (but uasyncio which I never used before).
I always download the firmware from "https://micropython.org/download/all/" and this time I downloaded this one: "https://micropython.org/resources/firmw ... -v1.14.bin".
This seems the last stable release, isn't it?
kevinkk525
Post by kevinkk525 » Sun Feb 07, 2021 7:27 pm
that's right. Looks like you're doing it correctly.
You could try the daily firmware until we can find out whats happening (assuming the daily firmware has uasyncio v3 which I assume it does).
Kevin Köck
enzo
Post by enzo » Sun Feb 07, 2021 7:48 pm
I'll give it a try and let you know.
enzo
Post by enzo » Sun Feb 07, 2021 7:57 pm
Same problem with last unstable:
MicroPython v1.14-9-g9dedcf122 on 2021-02-07; ESP module (1M) with ESP8266
>>> %Run -c $EDITOR_CONTENT
  File "<stdin>", line 20, in <module>
>>> import uasyncio
>>> dir(uasyncio)
I see there's a "uasyncio" method in "uasyncio" module so I tried:
>>> uasyncio.uasyncio.run()
but no success.
