Save the software inside ESP32
giants
Post by giants » Fri Feb 19, 2021 10:27 pm
Hi there !
I wrote a proram for my ESP32 with uPyCraft_V1.1. Everthingh work but i don't understand why if i turn off and turn on the current i need the save again the software inside the ESP 32, i need the change or write somethingh inside the boot ?
Thanks soo much
Sergio
Re: Save the software inside ESP32
Post by jimmo » Mon Feb 22, 2021 3:50 am
To make development faster, uPyCraft is just copying your code into RAM to be executed.
If you want to copy your code to the device, you need to copy your files to the device, and then main.py will be executed automatically on boot. I don't know if uPyCraft can do this, but I would recommend taking a look at:
- pyboard.py
- rshell
- Thonny
giants
Post by giants » Mon Feb 22, 2021 5:48 am
Thank you
Sergio
