Access Point - Extract query from URL
skywest
Post by skywest » Sat Feb 20, 2021 8:55 pm
Complete MicroPython newbie here.
I have set up an ESP8266 as access point and defined a simple web page served to any browser connecting to it.
If the browser connects to the access point with a query string attached to the url, e.g 192.168.4.1?var1=10&var2=20 ..... etc., what method would the ESP8266 use to extract these values from the url?
Any pointers appreciated!
Re: Access Point - Extract query from URL
Post by jimmo » Fri Feb 26, 2021 1:21 am
Can you provide more information about how your web server works?
When the browser connects to http://hostname/foo/bar?a=b it will say
GET /foo/bar?a=b HTTP/1.1
Host: hostname
So you can extract the url parameters from the GET line. In Python the easiest way to do this (if your web server library doesn't already do this for you) is using split.
