[Solved] rshell timed out or error in transfer to remote: b'F'
Posted: Mon Feb 22, 2021 7:09 am
Found a few threads which suggest that this error message is generated by rshell, I first noticed it when I built v1.14 source for the ESP8266 and tried to flash it.
don't know what this refers to, but this seems relevant
I am guessing None should be something else.
Any suggestions?
cp /home/dave/ESP-07S_Datalogger_project/boot.py /pyboard/
Executing "cp /home/dave/ESP-07S_Datalogger_project/boot.py /pyboard/"
----- About to send 458 bytes of code to the pyboard -----
def get_mode(filename):
"""Returns the mode of a file, which can be used to determine if a file
exists, if a file is a file or a directory.
import os
# Since this function runs remotely, it can't depend on other functions,
# so we can't call stat_mode.
return os.stat(filename)[0]
except OSError:
return 0
output = get_mode('/')
if output is None:
print("None")
print(output)
----- About to send 2257 bytes of code to the pyboard -----
def recv_file_from_host(src_file, dst_filename, filesize, dst_mode='wb'):
"""Function which runs on the pyboard. Matches up with send_file_to_remote."""
import sys
import ubinascii
import os
if False:
usb = pyb.USB_VCP()
except:
usb = machine.USB_VCP()
except:
usb = None
if usb and usb.isconnected():
# We don't want 0x03 bytes in the data to be interpreted as a Control-C
# This gets reset each time the REPL runs a line, so we don't need to
# worry about resetting it ourselves
usb.setinterrupt(-1)
with open(dst_filename, dst_mode) as dst_file:
bytes_remaining = filesize
if not False:
bytes_remaining *= 2 # hexlify makes each byte into 2
buf_size = 30
write_buf = bytearray(buf_size)
read_buf = bytearray(buf_size)
while bytes_remaining > 0:
# Send back an ack as a form of flow control
sys.stdout.write('\x06')
read_size = min(bytes_remaining, buf_size)
buf_remaining = read_size
buf_index = 0
while buf_remaining > 0:
if False:
bytes_read = sys.stdin.buffer.readinto(read_buf, read_size)
bytes_read = sys.stdin.readinto(read_buf, read_size)
if bytes_read > 0:
write_buf[buf_index:bytes_read] = read_buf[0:bytes_read]
buf_index += bytes_read
buf_remaining -= bytes_read
if False:
dst_file.write(write_buf[0:read_size])
dst_file.write(ubinascii.unhexlify(write_buf[0:read_size]))
if hasattr(os, 'sync'):
os.sync()
bytes_remaining -= read_size
return True
except:
return False
output = recv_file_from_host(None, '/boot.py', 145)
if output is None:
print("None")
print(output)
-----Response-----
b'16384\r\n'
Any suggestions?
