I've been trying for days now to have my SF6W wake up on X1 after a deepsleep.
First of all let me explain my configuration.
the board (firmware v1.13) is "externally" powered via it's VUSB Pin, and controls a MMA5284Q (accelerometer) via I2C.
The MMA5284Q is configured to raise a interrupt on a tap, this will lower the INT pin (from 3v3 to 0v).
I read that the X1 wakeup can only work if you raise the pin, therefore I've added a PNP transistor that will reverse the process.
checking with multimeter shows that it works.
if I try to go to lightsleep everything works fine. the board goes to sleep, and is successfully woke up on the tap.
if I try to go to deepsleep the board never wakes up, although I can see the interruption (multimeter) being raised from the MMA5284Q.
I guess I'm doing something wrong, but I can't figure what
If you need more information, please ask.
here the test code:
from pyb import Pin, ExtInt, LED, Switch
import MMA8452Q
STOP=False
ledR = LED(1)
ledG = LED(2)
# turn of red led as it was turned on in boot.py
ledR.off()
sw = Switch()
def stop():
global STOP
global sw
print("in stop")
STOP = True
sw.callback(stop)
def wokeUP(line):
print("pin change", line)
def loop(i2c):
global STOP
Accel = MMA8452Q.MMA8452Q(i2c)
# configure the accel to raise interrupt on Z tap
Accel.setupTap(0x80, 0x80, 0x08, True)
ledG.on()
while STOP is False:
print("sleeping in 3")
time.sleep(3)
#machine.lightsleep()
machine.deepsleep()
#need to readTap to reset the interrupt
print("tapState: " + str(Accel.readTap()))
time.sleep(1)
ledG.off()
#ext = ExtInt(Pin('X1'), ExtInt.IRQ_RISING, Pin.PULL_UP, wokeUP)
pinX1 = Pin("X1", Pin.IN, Pin.PULL_DOWN)
pinX1.irq(trigger=Pin.IRQ_RISING, handler=wokeUP)
i2c = machine.I2C('X')
s = i2c.scan()
if len(s) > 0:
loop(i2c)
