Questions and wish list about Pyboard D
devnull
Re: Questions and wish list about Pyboard D
Post by devnull » Fri Mar 29, 2019 9:24 am
Hi Peter:
>>> import sys
>>> sys.path
['', '/flash', '/flash/lib']
Post by pythoncoder » Fri Mar 29, 2019 9:49 am
Have you followed these instructions?
devnull
Post by devnull » Fri Mar 29, 2019 10:47 am
Hi Peter;
That has been updated in the last few minutes !
Just tried this:
os.mount(pyb.MMCard(), '/mmc')
sys.path.append('/mmc')
pyb.usb_mode('VCP+MSC', msc=(pyb.MMCard(),))
pyb.MMCard().power(1)
Also ran this: https://pybd.io/resources/mmc_format.py - which appeared to run successfully.
But still don't see anything - maybe it's not supported yet.
Post by Roberthh » Fri Mar 29, 2019 2:34 pm
A few questions now that the Pyboard D is out in the wild:
- where are the firmware binaries
- where is the firmware repository
At least the binaries should show up on the download page.
ThomasChr
Post by ThomasChr » Fri Mar 29, 2019 2:40 pm
Would like to know that, too.
Got an error with setting the frequency and -maybe- I can figure out whats wrong. But not without the source code...
uCTRL
Post by uCTRL » Sat Mar 30, 2019 1:11 am
How many connections are permitted or possible to Pyboard D WiFi when set to WiFi Access Point mode?
ESP32 in AP mode supports up to 4 connections.
Is there any more detailed documentation available for D yet, or only a quick start guide?
https://pybd.io/index.html
