Pyboard D: Can't switch to 216 MHz
Re: Pyboard D: Can't switch to 216 MHz
That was a completely fresh started Pyboard without anything running.
There is now an issue for my problem: https://github.com/micropython/micropython/issues/4662
That worked. Deactivating USB and reactivating after lightsleep() works.machine.lightsleep(ms) should also work, but the USB will not during a lightsleep, you need to do pyb.usb_mode(None) to disable it.
I have absolutely no problem switching to 216 MHz on my Linux Box with 'screen' or with Putty.
So either Putty on Windows has a problem or the USB Driver has some kind of problem...
Both @Damien and myself have encountered (on Linux) the problem where the prompt does not appear until you press Enter. I've not been able to replicate the crash (so far).
