WiFi throughput performance using (u)iperf3
Damien
Site Admin
Post by Damien » Wed Apr 03, 2019 8:25 am
To test WiFi throughput on the PYBD as it was being developed, I wrote a Python module implementing the iperf3 protocol. It's on PyPI as uiperf3 and can be installed on a PYBD using upip.install('uiperf3').
To test performance, run normal iperf3 on your PC in server mode (iperf3 -s) and then on the PYBD use:
import uiperf3
uiperf3.client("ip-of-PC")
Client mode supports the "reverse" and "udp" keyword args to select different modes (it defaults to TCP sending), and "bandwidth" in bits per second. It also supports server mode via uiperf3.server().
Throughput is heavily dependent on how much traffic is already on the WLAN, and also other environmental (physical) factors. Here is a typical output trace running on a PYBD_SF2W:
>>> uiperf3.client('192.168.1.221')
CLIENT MODE: TCP sending
Connecting to ('192.168.1.221', 5201)
Interval           Transfer     Bitrate
  0.00-1.00   sec   902 KBytes  7.38 Mbits/sec
  1.00-2.00   sec   929 KBytes  7.61 Mbits/sec
  2.00-3.00   sec   958 KBytes  7.85 Mbits/sec
  3.00-4.00   sec  0.98 MBytes  8.21 Mbits/sec
  4.00-5.00   sec   991 KBytes  8.11 Mbits/sec
  5.00-6.00   sec   911 KBytes  7.46 Mbits/sec
  6.00-7.00   sec   953 KBytes  7.80 Mbits/sec
  7.00-8.00   sec   920 KBytes  7.53 Mbits/sec
  8.00-9.00   sec   941 KBytes  7.71 Mbits/sec
  9.00-10.00  sec   923 KBytes  7.56 Mbits/sec
 10.00-10.00  sec  0.00 Bytes  0.00 bits/sec
  0.00-10.00  sec  9.21 MBytes  7.72 Mbits/sec  sender
  0.00-11.26  sec  9.21 MBytes  6.86 Mbits/sec  receiver
>>> uiperf3.client('192.168.1.221', reverse=1)
CLIENT MODE: TCP receiving
  0.00-1.00   sec   870 KBytes  7.13 Mbits/sec
  1.00-2.01   sec   873 KBytes  7.12 Mbits/sec
  2.01-3.01   sec   782 KBytes  6.38 Mbits/sec
  3.01-4.01   sec   806 KBytes  6.60 Mbits/sec
  4.01-5.01   sec   771 KBytes  6.30 Mbits/sec
  5.01-6.01   sec   817 KBytes  6.68 Mbits/sec
  6.01-7.02   sec   858 KBytes  7.03 Mbits/sec
  7.02-8.02   sec   835 KBytes  6.82 Mbits/sec
  8.02-9.02   sec   867 KBytes  7.08 Mbits/sec
  9.02-10.00  sec   829 KBytes  6.93 Mbits/sec
  0.00-10.00  sec  8.11 MBytes  6.80 Mbits/sec  sender
  0.00-10.41  sec  8.51 MBytes  6.85 Mbits/sec  receiver
cccc
Re: WiFi throughput performance using (u)iperf3
Post by cccc » Sat Feb 15, 2020 7:58 pm
use it at esp8266 port, and end up with a error below:
https://imgur.com/a/NVwWAzq
