Stuck with green LED on constantly?
farrrell504
Post by farrrell504 » Wed Apr 17, 2019 10:16 pm
I'm guessing I got one of these boards in a weird state as now the green LED next to the reset button is constantly on and the board no longer appears as a drive or com port. I've tried hitting the reset button and connecting the boot pin to 3v3 then hitting the reset button as well. Does anyone have any thoughts on what's going on with the board? And is there any documentation on the various states the board can be in? I've checked https://pybd.io/ but there's no mention of this.
rhubarbdog
Re: Stuck with green LED on constantly?
Post by rhubarbdog » Thu Apr 18, 2019 8:19 am
Try holding down the USR switch and reset. Release reset. Release USR when the light is blue to do a factory reset of your flash.
farrrell504
Post by farrrell504 » Fri Apr 19, 2019 1:27 am
I'll try this out when I get to work in the morning! Thank you!
How did you know to recommend this sequence? Is there documentation somewhere that I'm overlooking?
rhubarbdog
Post by rhubarbdog » Fri Apr 19, 2019 3:25 am
I read it in this thread
[Edit]
Have you tried from a serial terminal to get a REPL prompt and type
pyb.LED(2).off()
farrrell504
Post by farrrell504 » Tue Apr 23, 2019 2:06 am
The holding down the buttons and releasing in that order unfrooze the board! Wish there was some documentation on this stuff though...
rhubarbdog
Post by rhubarbdog » Tue Apr 23, 2019 6:05 am
There will be. Pyboard d is really new
