This is the way the other Pyboard D attachments are designed: mechanical interference with the Pyboard precludes incorrect insertion. So I'd consider it keyed.mnelsoneorm wrote: ↑Sat Jun 01, 2019 6:31 am...
There's no bump, but I did just try to align the connectors and it can only go on one way. One whole end of the board is too long (by like 0.5mm) and bumps into the SD card holder. I guess that would be considered keyed?...
EMMC Flash Mounting issues
Re: EMMC Flash Mounting issues
I just received my EMMC Flash module today. My module does not include the "bump" or alignment key on the corner either. The photo above indicated the proper alignment.
Now on to see if I can format and mount the module.
Thank you,
v/r
Jeff
Thank you,
v/r
Jeff
