Firmware for PyBoard D
neoxharsh
Post by neoxharsh » Wed Sep 11, 2019 9:46 pm
I am not able to find the firmware for the PyBoard D on the download page. Can anyone help me with it?
And does the LCD Skin connected to PyBoard D have faster refresh rate?
Cheers
Re: Firmware for PyBoard D
Post by pythoncoder » Thu Sep 12, 2019 7:52 am
Something has gone wrong with the download page, I have raised an issue so hopefully it will be fixed soon.
As for the LCD skin subjectively it's similar to the Pyboard 1.x. In practice the refresh rate tends to depend on how you're using it.
neoxharsh
Post by neoxharsh » Fri Sep 13, 2019 12:40 am
Thanks, I see now the firmware page is updated.
As for the lcd, I wanted to know is refreshing the entire screen fast? can we see the refresh happening?
Post by pythoncoder » Fri Sep 13, 2019 6:16 am
The official test running on a Pyboard 1.1 reports 28fps drawing some fairly complex graphics. Actual rates are likely to depend on exactly what you're drawing.
chuckbook
Post by chuckbook » Fri Sep 13, 2019 10:35 am
Re: LCD160CR_1.1 screen update
Theoretical limit for full screen updates using SPI fast protocol is 97 Hz.
This requires a 32 MHz SPI clock.
Smaller rectangular areas can be processed even faster.
However, this technique requires a full frame buffer in host MCU RAM.
(Original LCD160CR has a max. SPI clock of 13.5 MHz.)
