Bluetooth BLE tests
devnull
Bluetooth BLE tests
Post by devnull » Sun Oct 06, 2019 11:05 am
Just thought I would post this test code on the newly merged bluetooth, many thanks to @jimmo for making this happen and for the sample code from which this was created.
1. import the ble module below
2. on you phone (iphone) settings > bluetooth and connect PYBD device (may be advertised as ESP32)
3. On the iphone, open the Health app.
4. Send a new value to the iphone HEART RATE: ble.send(88)
If anybody else has any useful code snippets for BLE, would be interested to see / test it !
ble.py
import bluetooth
bt = bluetooth.BLE()
bt.active(True)
UUID_HR = const(0x2A37)
_IRQ_ALL = const(0xffff)
HR_SERVICE = bluetooth.UUID(0x180D)
HR_CHAR = (bluetooth.UUID(UUID_HR), bluetooth.FLAG_READ|bluetooth.FLAG_NOTIFY,)
CID = None
((HR,),) = bt.gatts_register_services(((HR_SERVICE, (HR_CHAR,),),))
def bt_irq(event, data):
  # >> bt irq 1 (64, 1, b'Y\xeb\n@uZ')
  global CID
  CID,EID,DATA = data
  print('connected > evt:{} id:{} eid:{} data:{}'.format(event,CID,EID,DATA))
bt.irq(bt_irq, _IRQ_ALL)
def adv_encode(adv_type, value):
  return bytes((len(value) + 1, adv_type,)) + value
def adv_encode_name(name):
  return adv_encode(0x09, name.encode())
def adv():
  bt.gap_advertise(100, adv_encode(0x01, b'\x06') + adv_encode(0x03, b'\x0d\x18') + adv_encode(0x19, b'\xc1\x03') + adv_encode_name('esp32hr'))
def send(val=0):
  # b'\x00\x42'
  ba = bytearray(2)
  ba[1]=val
  bt.gatts_notify(64, HR, ba)
adv()
BLE n00b question
Post by pythoncoder » Sun Oct 06, 2019 3:03 pm
Is it possible to use BLE as a communication channel between Pyboard D's?
Re: BLE n00b question
Post by jimmo » Sun Oct 06, 2019 3:53 pm
Yes. Right now you do that by having one of them acting as a peripheral, the other as a central and then they can exchange data over a characteristic value.
There's an abstraction built on top of this called the Nordic Uart Service (NUS) which make it look like a UART.
We're also keen to investigate implementing BLE Mesh.
devnull
Re: Bluetooth BLE tests
Post by devnull » Mon Oct 07, 2019 4:55 am
@jimmo - Do you have a code snippet for this ??
Also, I already reported this on github and is a small matter, but the pyboard D seems to advertise itself as a ESP32 device prior to initial pairing / connection.
Post by jimmo » Mon Oct 07, 2019 11:05 pm
Yeah working on documentation and code samples this week.
I'll reply on github in more detail, but are you using the exact same code snippet above. The advertising payload is includes adv_encode_name('esp32hr'), so I'd expect you see "esp32hr" in a scan?
There's no pairing support yet, but on connection you see the device's actual name. On STM32 it defaults to "PYBD", on ESP32 the plan is to make it default to "ESP32". Perhaps this should be "MPY" (or maybe it should be configurable).
devnull
Post by devnull » Thu Oct 17, 2019 9:33 am
@jimmo - I have just received some BLE 5.0 beacons from Alibaba.
Do you have any example code that shows how I configure as a a Master, scan for and connect to a BLE slave ??
I know you mentioned you were working on some documentation ?
PeterC
