BLE Broadcasts vs Scans
devnull
Post by devnull » Wed Nov 06, 2019 3:26 am
Sorrie for all of the BLE questions, I have googled but are not able to find a direct answer.
It appears that beacons broadcast and that it is not necessary to connect to the device, but just to listen for a specific device broadcast and read it's data.
But how would you do this ? - I know that with a scan you get a list of nearby devices, but how do you actively listen for broadcasts from devices ??
Re: BLE Broadcasts vs Scans
Post by jimmo » Wed Nov 06, 2019 3:52 am
A beacon is an advertiser that includes some application-specific data in its advertising payload. (Normally, devices would use this payload to indicate which services they support, appearance, name, etc).
A scanner sees the advertising payload and extracts the beacon data.
This process is entirely passive -- the advertiser just sends out its advertising messages at some interval, the scanner listens on the three channels and opportunistically receives these messages. (This is why the window and interval parameters to gap_scan are important)
Unfortunately the advertising payload is tiny. So there is an extension to this called "active scanning" where the scanner can then attempt to query an advertiser for more data (this is the scan_resp kwarg to gap_advertise). (This is different to connecting, it's just a message that the scanner can send to an advertising device, to which the advertising device will respond with this additional data).
The MicroPython API supports a beacon setting the scan_resp data, but does not currently support a scanner receiving it (we always do "passive scans"). I plan to add this later.
devnull
Post by devnull » Wed Nov 06, 2019 4:11 am
Jimmo, thanks, that's very helpful.
I have already checked the scan manufacturer's data and it does not contain active data, only static data such as the mac address and a couple of other byte variables.
b"\x02\x01\x06\x03\x02 \xaa\x0e\xff\x00\x1f\x00\x00B\x01d\xcb\xd0\xc5\x0c'\xbd"
devnull
Post by devnull » Wed Nov 06, 2019 5:32 am
Also, not sure if this is related to the gap-scan timing you mentioned, but very often devices which the mac is known and can be connected to do not appear in the scan results, whether or not they are already connected.
Only if I scan several times for a minute at a time will these devices be eventually discovered.
Post by jimmo » Wed Nov 06, 2019 5:35 am
Yes it's most likely exactly that. Try:
ble.gap_scan(duration_ms, 30000, 30000)
which is the fastest allowable scan. The default is that it spends a lot of time sleeping in order to save power. See https://github.com/micropython/micropython/pull/5190 for more info.
devnull
Post by devnull » Wed Nov 06, 2019 7:40 am
Yes, using those options it finds the devices immediately
