External Interrupts not working.
pynewt
Post by pynewt » Sun Dec 22, 2019 3:32 am
Hello all,
I'm very new to micropython and jumped in by purchasing a pyboard d-series (SF2W) to use as a learning tool for python in general. Currently I'm experiencing an issue with setting up an pushbutton to trigger an external interrupt. So far, I'm not having any luck following the official documentation. the code I'm using is very simple as this was just to test the functionality.
from pyb import ExtInt, Pin, LED
led = LED(1)
#Wired the button between pin 'X6' and the X GND
ex1 = ExtInt('X6', ExtInt.IRQ_FALLING, Pin.PULL_UP, led.toggle())
Is there something I'm missing?
Re: External Interrupts not working.
Post by pythoncoder » Sun Dec 22, 2019 7:11 am
There are two problems The first is that you're specifying the callback with parentheses: this will cause it to run once, returning None (Python functions return None by default). None is then being assigned to the ISR callback. The second is that the callback expects a single arg, and led.toggle() does not. Try adding your own callback:
import micropython
led = LED(1)
def callback(arg):
    led.toggle()
ex1 = ExtInt('X6', ExtInt.IRQ_FALLING, Pin.PULL_UP, callback)  # No parens
See the docs to understand the thaumaturgy in line 3. tl;dr it helps with error messages if you make a mistake in a callback.
pynewt
Post by pynewt » Sun Dec 22, 2019 8:32 am
Thank you so much! I was misreading the line from the documentation and not realizing the importance of the presence of an argument.
callback is the function to call when the interrupt triggers. The callback function must accept exactly 1 argument, which is the line that triggered the interrupt.
It works exactly as intended now.
