How to wake on TAMP1 (PC13)..?
incognico
Post by incognico » Thu Jun 11, 2020 8:28 am
Hi all,
Anyone with working code to wake a PYBD from Standby using PC13? I have been hacking at this on and off for a while, but I'm clearly missing something in the 1954-page datasheet :?
Appreciate any insight!
Cheers,
--Nick
incognico
Re: How to wake on TAMP1 (PC13)..?
Post by incognico » Fri Jun 12, 2020 6:29 am
Well, a bucket of coffee this morning and a fresh look and it was just me being stupid. Couple of registers have changed names that I managed to miss several times through... I was looking for something far more complicated and missed the simple stuff :lol:
For example, to make Peter's upower library Tamper() work on the PYDB, just rename the registers...
PWR_CR -> PWR_CSR2
RTC_TAFCR -> RTC_TAMPCR
Post by pythoncoder » Sat Jun 13, 2020 5:42 am
Adapting that library to support Pyboard D is on my (very long) TODO list. I wonder how many other names need to be changed.
I have amended upower.py to detect a Pyboard D and make those changes if you'd like to try it.
incognico
Post by incognico » Mon Jun 15, 2020 3:17 am
Just a couple of small things by the looks of it -
An oldie but a goodie :)
>>> import upower
  File "upower.py", line 20, in <module>
AttributeError: type object 'board' has no attribute 'USB_VBUS'
Looks like X18 is removed from the board definitions (I'm just using cpu.C13).
>>> tamper=upower.Tamper()
  File "upower.py", line 34, in getinstance
  File "upower.py", line 113, in __init__
AttributeError: type object 'board' has no attribute 'X18'
My application has the line going high to trigger the interrupt (level=1). I changed the pin setup to PULL_DOWN, and in addition to your code I needed to disable the tamper pullup/precharge (set RTC_TAMPCR bit 15). Pg 1167:
Bit 15 TAMPPUDIS: RTC_TAMPx pull-up disable
This bit determines if each of the RTC_TAMPx pins are precharged before each sample.
0: Precharge RTC_TAMPx pins before sampling (enable internal pull-up)
1: Disable precharge of RTC_TAMPx pins.
Also specific to my application, I'm using the Tamper line as a general wake-up interrupt, not a security "tamper" mechanism, so I did not want the backup registers to be deleted. I needed to set RTC_TAMPCR bit 17 to achieve this. Pg 1167:
Bit 17 TAMP1NOERASE: Tamper 1 no erase
0: Tamper 1 event erases the backup registers.
1: Tamper 1 event does not erase the backup registers.
Hope this is useful.
--Nick
Post by pythoncoder » Mon Jun 15, 2020 7:11 am
Very useful indeed, Nick. Thank you. Clearly the behaviour for level 1 was incorrect for Pyboard 1.x too. I've pushed an upgrade to address the points you've made.
It seems that the erasure of backup registers is specific to the Pyboard D: chip data for the V1.x assigns a different meaning to bit 17 so I've made that Pyboard D specific.
I wonder what else has been broken on the Pyboard D: which other features of upower.py have you used? Have you measured the current draw when in low power mode?
incognico
Post by incognico » Tue Jun 23, 2020 3:02 am
Hi Peter,
Sorry I thought I replied to this at the time but clearly I imagined it.
I haven't tried the other features/modes of the upower library sorry. I hope to get the opportunity to give it a thorough run through at some stage but there always seems to be something urgent requiring attention first. I will see if I can find a moment to throw a fresh PYBD on the bench and test current draw (my dev unit has had a hard life and now appears to baseline at ~35mA no matter what is shut down...!)
--Nick
