permission denied deleting folder
MrRobot
Post by MrRobot » Wed Jun 17, 2020 3:57 pm
So I have the following code that I've been using to experiment with file system limits on my Pyboard D:
import uos
import uerrno
import sys
uos.mkdir('test')
    for x in range(10000000):
            uos.listdir('test')
        except Exception as e:
            print('Error indexing files: ',e)
            print('x:',x)
            uos.sync()
            sys.exit()
        filename = 'test/' + str(x) +'.json'
        with open(filename, "w") as file:
            file.write('testing of file system limits')
        uos.sync()
    print(e)
    print('Limit :',x)
Once this code has ran I have a folder called test that has loads of tester files in it.
When I enter the command :
 os.rmdir('test')
I get the following Error : OSError: [Errno 13] EACCES
Which has something to do with file permissions.
Anyone know why I can't delete this folder?
The only option I have is to mount it on my PC and manually delete the folder.
Re: permission denied deleting folder
Post by Roberthh » Wed Jun 17, 2020 5:20 pm
rmdir requires the folder to be empty. So you have to delete the files first. That' s what the PC software does under the hoid.
Post by pythoncoder » Thu Jun 18, 2020 5:24 am
The files can be deleted in code, but I suggest you try rshell for communication with a Pyboard. I use it continuously. At the rshell prompt you can issue
rm -r /sd/test
and the job is done. It supports many other useful features.
