SD Card not registering on Pyboard SF6W
kbrenner
Post by kbrenner » Thu Jul 09, 2020 4:28 pm
I have a Lexar 32GB SD card attached to the SF6W. I have several SF6W's, and it has worked on others, but for this device, it won't register it. I have confirmed that sys.path does not show '/sd', and upon trying to access '/sd', I recieve OSError: [Error 19] ENODEV. Has anyone else experienced this or have any troubleshooting suggestions?
Best,
Kevin
Re: SD Card not registering on Pyboard SF6W
Post by jimmo » Mon Jul 13, 2020 2:03 am
This indicates it's probably not something you're doing wrong!
I assume you're doing:
import os
os.mount(pyb.SDCard(), "/sd")
I guess the main thing I'd try is to see if the block device works at all:
b = pyb.SDCard()
print(b.read(0))
I get a block ending in b'U\xaa' with a partition table in the final 64 bytes.
