EACCES issue with '/sd' subdirectory
kbrenner
Post by kbrenner » Thu Nov 19, 2020 3:45 pm
I am attempting to remove a directory on the SD card on the PYBD-SF6W. I am using the command os.rmdir(<name of directory>); however, I am receiving the following error:
>>> os.rmdir('ControllerData')
OSError: [Errno 13] EACCES
Does anyone know why this might be occurring?
Re: EACCES issue with '/sd' subdirectory
Post by dhylands » Thu Nov 19, 2020 4:02 pm
Did you try using "os.rmdir("/sd/ControllerData") (or whatever the correct path is) and is the directory empty?
os.rmdir("ControllerData") will try to remove the file from the current directory, which I think by default would be /
