ENOMEM error
kbrenner
ENOMEM error
Post by kbrenner » Mon Jan 11, 2021 3:00 am
I am using a PYBD-SF6W and am running into an error while sending BLE messages. The REPL prompt just gets flooded with the following messages:
ENOMEM error.PNG (19.66 KiB) Viewed 907 times
Does anyone know where these get generated? If there isn't a way right now to avoid them, is there a way to recognize that the error is occurring and reset something to make them go away (i.e. ensure they only occur on one frame and then get back on track)? Thanks!
Re: ENOMEM error
Post by jimmo » Mon Jan 11, 2021 3:37 am
Confusingly, ENOMEM here comes from the BLE stack being unable to allocate internal buffers. It doesn't (necessarily) mean that the Python heap ran out of memory.
Generally this shouldn't be possible from user code (i.e. we should turn these errors into something easier to debug).
Are you able to share any more details about what your code is doing? Is it a GATT server or client? Peripheral or central? Using any more advanced features (l2cap, pairing/bonding, etc)? Can you share your code?
I did fix a bug late last year in https://github.com/micropython/micropython/pull/6717 but not sure that explains what your'e seeing.
Re: ENOMEM error
Post by jimmo » Mon Jan 11, 2021 3:39 am
Another option... are you compiling your own firmware? If so, a build with DEBUG_printf enabled (line 55 of extmod/nimble/modbluetooth_nimble.c) would probably be useful for tracking this down.
monquarter
Re: ENOMEM error
Post by monquarter » Mon Jan 11, 2021 4:50 pm
Additionally, I notice that it is not possible to configure that rxbuf parameter associated with the ble.
MPY: sync filesystems
MPY: soft reboot
MicroPython v1.13-268-gf7aafc062 on 2021-01-11; PYBD-SF6W with STM32F767IIK
>>> import ubluetooth
>>> ble = ubluetooth.BLE()
>>> ble.active(True)
True
>>> ble.config('rxbuf')
ValueError: unknown config param
>>> ble.config(rxbuf=1024)
Re: ENOMEM error
Post by jimmo » Mon Jan 11, 2021 11:48 pm
Since v1.13 (i.e. the current unstable code) on STM32 and Unix when using the NimBLE stack, there is no longer a ringbuffer of pending events. The events get delivered directly via the scheduler.
I will update the docs.
monquarter
Re: ENOMEM error
Post by monquarter » Tue Jan 12, 2021 2:44 pm
I made a build as suggested by jimmo with debug flag enabled, and modified the ble_temperature to send data more quickly to a second pyboard-DSF6 running ble_central.py example. See viewtopic.php?f=20&t=8844 for more info on the test setup.
nimble: characteristic_access_cb: conn_handle=65535 value_handle=21 op=0
nimble: gap_event_cb: type=13
nimble: gap_event_cb: notify_tx: 0 0
nimble: ble_hs_err_to_errno: 0
nimble: gap_event_cb: notify_tx: 0 6
nimble: ble_hs_err_to_errno: 6
  File "ble_temperature.py", line 91, in demo
  File "ble_temperature.py", line 72, in set_temperature
OSError: [Errno 12] ENOMEM
