firmware build appended with "dirty", no longer allowing CTRL-D to work
kbrenner
Post by kbrenner » Wed Jan 27, 2021 2:00 am
Hi, I'm running a PYBD SF6W with V1.13 firmware. Recently, CTRL-D stopped rebooting the pyboard properly. I checked boot.py, and it is untouched/uncorrupted. However, I am receiving the following print out for the firmware version:
MicroPython Error.PNG (7.52 KiB) Viewed 3110 times
What does it mean to have the word "dirty" appended to the firmware build?
davef
Re: firmware build appended with "dirty", no longer allowing CTRL-D to work
Post by davef » Wed Jan 27, 2021 2:32 am
viewtopic.php?f=2&t=8992
Maybe this helps.
kbrenner
Post by kbrenner » Wed Jan 27, 2021 3:16 pm
Maybe this helps.
Thank you. I actually wasn't using Git for my code, but instead, I just found a clean backup copy of the code and copied it over and it solved the problem.
