Long press button
soggycashew
Long press button
Post by soggycashew » Sun Oct 17, 2021 4:51 am
Is there a way to detect a long press on a button? For example, lets say I have one button and two LEDs long press turns on the second led but short press turns on the first LED.... If so how can I do it?
Thanks,
Re: Long press button
Post by pythoncoder » Sun Oct 17, 2021 7:30 am
See this doc, notably the Pushbutton class.
soggycashew
Post by soggycashew » Sun Oct 17, 2021 8:35 pm
Peter, I read that github page and it is very confusing to me since im new to coding and python in general. Can you give me an example for a button single press then long press so I can test it on my breadboard?
Thanks,
Post by pythoncoder » Mon Oct 18, 2021 2:18 pm
Try this, which works on my Pico:
from primitives.pushbutton import Pushbutton
import uasyncio as asyncio
led = Pin(25, Pin.OUT)  # On board LED
pin = Pin(0, Pin.IN, pull=Pin.PULL_UP)  # Pushbutton
def toggle():
    print("Press")
    led(not led())
def report():
    print("Long press")
def test():
    pb = Pushbutton(pin)
    pb.press_func(toggle, ())  # Callback on button press
    pb.long_func(report, ())  # Callback on long press
        await asyncio.sleep(1)
        print(pin())  # Print current pin state
    asyncio.run(test())
finally:
    asyncio.new_event_loop()
You will need to go to https://github.com/peterhinch/micropyth ... /master/v3 and copy the primitives directory with (at least) pushbutton.py and delay_ms.py to your board, keeping the directory structure. Link GPIO 0 to gnd with a pushbutton. You can just copy the whole directory: it takes a minute or so.
To learn about uasyncio, see my tutorial.
soggycashew
Post by soggycashew » Mon Oct 18, 2021 11:29 pm
@pythoncoder I'm getting an error in thonney....
  File "<stdin>", line 2, in <module>
  File "primitives/pushbutton.py", line 8, in <module>
ImportError: no module named 'primitives.launch'
I looked for a file named launch in the primitives folder on GitHub and there isn't one? On my Pico I created a directory called primitives and added the two files you specified and tried to run the code you gave in the thread. Is there other files I'm needing?
Thanks,
Post by pythoncoder » Tue Oct 19, 2021 8:52 am
Ah, sorry, you also need to copy primitives/__init__.py.
soggycashew
Post by soggycashew » Wed Oct 20, 2021 12:08 am
Sorry for the late reply I'm not getting notifications for some reason.... I'll give it a try thank you very much again!
