I am trying to write a datalogging program for a pi pico.
When I run the following code everything works fine:
import os, sdcard
sd = sdcard.SDCard(machine.SPI(1), machine.Pin(13))
os.mount(sd, '/sd')
except OSError :
print('already mounted')
If I run it a second time, I do not get the print('already mounted') message to come up. Is there something else I should be doing to get to code to run other commands is the sd card is already mounted?
Thank,
Doug
