LCD1602 error I2C
Maarten_apd
LCD1602 error I2C
Post by Maarten_apd » Tue Mar 09, 2021 3:03 pm
when i try to use my code to get started with using a lcd screen with my pico i get a error code
sda=machine.Pin(0)
scl=machine.Pin(1)
i2c=machine.I2C(0,sda=sda, scl=scl, freq=400000)
i2c.writeto(114, '\x7C')
i2c.writeto(114, '\x2D')
print(I2C.scan())
  File "<stdin>", line 5, in <module>
OSError: 5
Re: LCD1602 error I2C
Post by dhylands » Tue Mar 09, 2021 3:06 pm
It would be good to see the results of the scan.
You need to use i2c.scan() and not I2C.scan()
Maarten_apd
Post by Maarten_apd » Tue Mar 09, 2021 3:10 pm
after the change i got the same error
Maarten_apd
Post by Maarten_apd » Tue Mar 09, 2021 3:15 pm
sda=machine.Pin(0)
scl=machine.Pin(1)
print(i2c.scan())
[39]
the scan worked with this code with the other one it din't work
fdufnews
Post by fdufnews » Tue Mar 09, 2021 5:06 pm
In the first program, you try to write at address 114. If you have no I2C slave at that address you have no acknowledge and the write probably crashes.
In the second program the scan tells you that you have a slave at address 39 which maybe is an I2C expander.
Maarten_apd
Post by Maarten_apd » Wed Mar 10, 2021 8:42 am
this is the lcd with controller i use
lcd i use
WhatsApp Image 2021-03-10 at 09.40.12.jpeg (87.57 KiB) Viewed 11824 times
fdufnews
Post by fdufnews » Wed Mar 10, 2021 9:37 am
Default address on similar I2C adapter (using a PCF8574) is 0x27 (39 decimal) which is compliant with the address the scanner returned.
Post by dhylands » Wed Mar 10, 2021 11:16 pm
I have a driver already written for that board (or at least a board very similar to that), and I've tested it with the RPi Pico.
I had to power the LCD using 5v, so I used a 3.3v to 5v voltage converter for the SDA and SCL lines. The Pico doesn't have 5V tolerant pins.
See this post: viewtopic.php?f=12&t=9633&p=55356#p55356
You'll also need the lcd_api.py file: https://github.com/dhylands/python_lcd/ ... lcd_api.py (in addition to the 2 files mentioned in the post, although the test file is optional.
federico
Post by federico » Fri Jul 01, 2022 4:57 am
# Raspberry Pi Pico
# to test the with micropython 1.19
# OSError: [Errno 5]- EIO
# esp8266_i2c_lcd.py, line 55  in __init__
# the following is the code in line 55:
# self.i2c.writeto(self.i2c_addr, bytearray([0]))
# that set to OFF the LCD backlight
# !! with releases ver. <= 1.18 no problems
from machine import I2C, Pin
scl_pin=11
sda_pin=10
i2c_ID=1
i2c = I2C(i2c_ID, sda=Pin(sda_pin), scl=Pin(scl_pin))
i2c.scan()
if i2c.scan().count(39)  == 0:
    print("No i2c display found !")
    from esp8266_i2c_lcd import I2cLcd, DEFAULT_I2C_ADDR
    lcd = I2cLcd(i2c, DEFAULT_I2C_ADDR, 4, 20)
federico
Post by federico » Sun Jul 03, 2022 6:55 am
A retest with another RPi Pico with micropython release 1.19 installed was successful - which rules out problems with the new micropython release
