webrepl on the pico w ?
Hi!
Recently on raspberry pi forum with the help of @hippy (thanks again) I have tried to have webrepl running on a picoW.
Adding moduwebsocket.c and modwebrepl.c to a custom micropython build
Plus the 3 python files related to webrepl located in micropython/extmod/webrepl/ in picow /
It was almost successfull: I have been able to create a password in webrepl_cfg.py and modify boot.py to launch webrepl.
Unfortunatley as noted here it ended with dupterm missing in uos!
There is a file extmod/uos_dupterm.c but how to include it a custom build?
Is this even feasible or better to wait?
Thks
Thks
Re: webrepl on the pico w ?
That seems like an oversight... it's enabled on other rp2 boards with networking support.
Sent PR to standardise this across all rp2 boards: https://github.com/micropython/micropython/pull/8893
That's a good news.
Thank you very much @jimmo
Yes it works
I have recompiled with the files modified as per your pull request and successfully ran webrepl.
And accessed repl remotely via wifi.
Great
Webrepl is really a micropython super feature
Great
Hi!
I noticed that today's nightly build for the picoW v1.19.1.169 can run webrepl by adding these 3 python files:
They are located in micropython/extmod/webrepl and must be copied in the picow root directory or in /lib.
So even if they are not yet frozen modules it seems it's ready or almost ready (I noticed Ctrl-C isn't working in webrepl but maybe it's my setup)
So is there any announcement when it is officially ready or can we track it somewhere?
webrepl.py
webrepl_setup.py
websocket_helper.py
Thank you @jimmo
Several days ago I saw that pull request #8931 had been merged. But there was still no webrepl on nightly builds for picoW. I thought we had to wait some more.
But in fact today I saw that it works well on ESP8266 and as expected by this pull request (by entering http://board_ip_address:8266/ in the address bar of the browser). But not on picoW.
I found the following line is missing:
in the file: micropython/ports/rp2/boards/manifest.py
I tested it by building a new firmware.
I created an issue on github
I hope that helps.
include("$(MPY_DIR)/extmod/webrepl/manifest.py")
I hope that helps.
Oh! Sorry I misunderstood. Because the last modification (PR #8931) is included in the ESP8266 port, I thought that the choice about the following point ( #8928) had been done, in favor of the first option.
We need to decide:
- Should we freeze the webrepl Python files on all boards that include the webrepl C support (which is now controlled by MICROPY_PY_NETWORK)
- or. Make webrepl something that can be installed optionally (upip, etc) and document that, and leave it to specific boards that want to freeze it.
