UART not working with today's version of micropython
Re: UART not working with today's version of micropython
I do not know what a logic analyzer is but I do have a usb serial converter so I'll give that a try
Do you use threading in your code?
Simple logic analyzer: https://www.amazon.de/AZDelivery-%E2%AD ... 180&sr=8-5
Good for digital signals up to ~5 MHz. Very helpful.
Yes I do.
I have one core to handle the sensor interrupts and running a loop to do calculations and one core to handle IO to the Nextion and the ESP32.
Okay. Hooked it up to the usb-serial
this is what I get over the serial port:
page 0���msg.txt="heartrate=--"���msg.txt=""���msg.txt="init"���msg.txt="Starting wifi"���msg.txt="Connecting to network..."���m
sg.txt="10.0.0.138"���msg.txt="Getting data"���msg.txt="Start TEST in 5"���msg.txt="Start TEST in 4"���msg.txt="Start TEST in 3"
���msg.txt="Start TEST in 2"���msg.txt="Start TEST in 1"���page 2���page1.gTime.val=4���page1.gHeartRate.val=0���page1.gSpeed.va
l=57���page1.gStroke.val=51���page1.gDiissttaannccee..vvaall==77����page1.gSegProoggrreessss..vvaall==00�����page1.gSegTimee..vv
aall==22440000������ppage1.gSegDist.val=0���page1.gSSeeggNNrr..vvaall==11������page1.gSegTotal..vvaall==22������ppaaggee11..ggSS
eeggNNaammee..ttxxtt=="OHR"���page1.gTargetMin.txt="130"���page1.gTargetMax.txt="140"���page1.gTarget.txxtt==""""������ppaaggee1
1..gTargetSlide.vaall==00������ppaaggee11..ggTTaarrggeettCCoolloorr..vvaall==6644552200������page1.gTime.val=5���page1.gHeartRat
e.val=0���page1.gSpeed.val=57���page1.gStroke.val=51���page1.gDistannccee..vvaall==88������ppaage1.gSegProgressss..vvaall==00���
���ppaagge1.gSegTime.vaall==22440000������ppaaggee1.gSegDist.val=0���page1.gSeeggNNrr..vvaall==11������ppage1.gSegTotal..vvaall=
=22������ppaaggee11.gSegName.txt==""OOHHRR""������ppaaggee11.gTargetMin.txxtt==""113300""������ppaagge1.gTargetMax..ttxxtt==""11
4400""������ppage1.gTarget.txxtt==""""������ppaaggee11..gTargetSlide.vaall==00������ppaaggee11..ggTTaarrggeettCCoolloorr..vvaall
==6644552200������page1.gTime.val=5���page1.gHeartRate.val=0���page1.gSpeed.val=57���page1.gStroke.val=50���page1.gDistannccee..
vvaall==88������ppaage1.gSegProgressss..vvaall==00������ppaagge1.gSegTime.vaall==22440000������ppaaggee1.gSegDist.val=0���page1.
gSegNNrr..vvaall==11������ppaagge1.gSegTotal.vvaall==22������ppaaggee11..gSegName.txt=""OOHHRR""������ppaaggee11..gTargetMin.txt
="130"���page1.gTargetMax.txt="140"���page1.gTarget.txt==""""������ppaaggee11..ggTTargetSlide.val==00������ppaaggee11..ggTTaarrg
geettCCoolloorr..vvaall==6644552200������page1.gTime.val=5���page1.gHeartRate.val=0���page1.gSpeed.val=57���page1.gStroke.val=50
���page1.gDistaannccee..vvaall==88������ppage1.gSegProgresss..vvaall==00������ppaaggee1.gSegTime.val=2400���page1.gSeggDDiisstt.
.vvaall==00������ppaaggee11..ggSSeeggNNrr..vvaall==11������page1.gSegTotal.val=2���page1.gSegName.txt="OHR""������ppaaggee11..gg
TTaarrgetMin.txt="13300""������ppaaggee11..ggTTargetMax.txt="140"���page1.ggTTaarrggeett..ttxxtt==""""���page1.gTargeettSSlliidd
ee..vvaall==00������ppaaggee11..ggTTaarrggeettCCoolloorr..vvaall==6644552200������page1.gTime.val=5���page1.gHeartRate.val=0���p
age1.gSpeed.val=57���page1.gStroke.val=49���page1.gDissttaannccee..vvaall==88�����page1.gSegProoggrreessss..vvaall==00�����page1
.gSegTimee..vvaall==22440000������ppage1.gSegDist.val=1���page1..ggSSeeggNNrr..vvaall==11����page1.gSegToottaall..vvaall==22����
��ppage1.gSegName..ttxxtt==""OOHHRR""������ppage1.gTargetMiinn..ttxxtt==""113300""�����page1.gTargetMMaaxx..ttxxtt==""114400""��
��page1.gTargett..ttxxtt==""""������ppaagge1.gTargetSlidee..vvaall==00������ppaaggee11..ggTTaarrggeettCCoolloorr..vvaall==664455
2200������page1.gTime.val=5���page1.gHeartRate.val=0���page1.gSpeed.val=57���page1.gStroke.val=49���page1.gDistaannccee..vvaall=
=99������ppage1.gSegProgreessss..vvaall==00������ppaage1.gSegTime.vaall==22440000������ppaaggee1.gSegDist.val=1���page1.gSeggNNr
r..vvaall==11������ppaage1.gSegTotal.vvaall==22������ppaaggee11..gSegName.txt=""OOHHRR""������ppaaggee11..gTargetMin.txtt==""113
300""������ppaaggee1.gTargetMax.ttxxtt==""114400""������ppaage1.gTarget.txtt==""""������ppaaggee11..ggTargetSlide.val=00������pp
aaggee11..ggTTaarrggeettCCoolloorr..vvaall==6644552200������page1.gTime.val=5���page1.gHeartRate.val=0���page1.gSpeed.val=57���p
age1.gStroke.val=49���page1.gDistance.val=9���page1.gSegPrrooggrreessss..vvaall==00������ppaaggee11..ggSSeeggTTiimmee..vvaall==2
2440000������page1.gSegDist.val=1���page1.gSegNr..vvaall==11������ppaaggee11.gSegTotal.vall==22������ppaaggee11..ggSSegName.txt=
"OHHRR""
It is basically amazing that it even works some of the time.
OK. Sending frequent was the trigger. If I do that, I see errors too. Not doubling, but gaps. These should not occur either.
Can you try this firmware version: https://github.com/robert-hh/Shared-Stu ... rmware.uf2
running MicroPython v1.14-170-ga9bbf7083-dirty on 2021-04-15; Raspberry Pi Pico with RP2040
No improvement:
{"sessionid":"0_1_1618506200","startT":25227,"endT":35421,"staarrttDD""::2233111144,,""eeddDD""::3399666644,,""aavvggRR""::00}}
No improvement:
Not good. The erorr I had seen disappeared with that change. But it also disappeared with setting timeout.
About your set-up and threads:
- in which thread is the UART communication placed?
- can you try to run the UART test with only thread0 active?
Edit: I could replicate the bug when the UART send process is in thread 1. That's a starting point.
Edit 2: But it's very rare. not at frequent as in your printout.
Yes, my uarts are both running in thread_1
When enabling threading I see all kinds of errors, very rarely character doubling, more often just lock-up of the sending thread, or sending completely wrong data. So there seems to be a general issue or challenge with threads and interrupt. Maybe a stack overrun.
It does not matter in which thread the sending or maybe more specific the interrupt using task is running.
I was trying out the nightly build because I was having a problem with the sensor interrupt handler dying after about 40 minutes on the build I was using. So no luck there
Very odd that you do get errors but hardly ever the one I am seeing.
Thank you very much for taking the time to look at this.
