Pico W Micro Python MQTT of data to a RP4B
Re: Pico W Micro Python MQTT of data to a RP4B
I've had a further thought on this since posting.
I'm wondering if where I'm going wrong is that i need to used the "decode()" function in my RP4B mqtt subscriber since i used the "encode()" function in the Pico W to publish the data.
I'm also wondering if I should have a simple mqtt subscription script like the one above, and then "tap" into that with another separate script which runs my more "fancy" coding for displaying to the screen and writing to a file?
Using something like this at the beginning of my fancy script:
from MQTT.py import OS_Temp, OS_Hum, Pico_Temp
(Can i do this?)
Anyone got any helpful comments or insights?
(Can i do this?)
Hi all,
I have a BIG problem which i'm really begging for help on.
I'm afraid this is still Python at this point, not uPython. I've got my Pico W sending data reliably and before i try to make it more fancy, I simply want to complete the data path life-cycle from there to my overall end Python script for my desired functionality.
I've got my MQTT code working in my RP4B. Not the way i wanted, but it's collecting three individual messages, and i *think* i've managed to associate each of these readings with global variables for use outside of the defined message variables (please tell me if i've not done this at all, because i clearly have no way of testing this due to the next issue.)
I'm trying to call in my global variables in the script where i want to use these from the MQTT message collecting script.
This is a copy of my MQTT script called "MQTT_PW_Vars.py":
This produces the following:
Connected to MQTT Broker with result: 0
Received: 25.2 from Topic: PicoW/Pico_Temp
Received: 57.3 from Topic: PicoW/OS_Hum
Received: 22.2 from Topic: PicoW/OS_Temp
Received: 22.1 from Topic: PicoW/OS_Temp
When I use the following lines in my overall desired script, called "PicoW_Vars.py":
The above "MQTT_PW_Vars.py" code completely hijacks the "PicoW_Vars.py" programs actual programming for its own!?
I only want the three variables as a product of the MQTT scripted code, not the functionality to completely take over anything else i have written in my end script!
Please. I'm really confused. I'm not sure where else to ask for help.
#!/usr/bin/env python
#!/bin/bash
#MQTT_PW_Vars.py
import paho.mqtt.client as mqtt
broker = '192.168.0.51'
port = 1883
#keepalive = 120
mqttclient = "PiLogger"
client = mqtt.Client(mqttclient)
topic1 = "PicoW/OS_Temp"
topic2 = "PicoW/OS_Hum"
topic3 = "PicoW/Pico_Temp"
def on_connect(client, userdata, flags, rc):
if rc == 0:
print(f"Connected to MQTT Broker with result: {rc}")
print("Failed to connect to Broker, return code = ", rc)
def on_disconnect(client, userdata, rc):
if rc != 0:
print("Unexpected disconnection!")
def on_message1(client, userdata, message):
print(f"Received: {(message.payload.decode('utf-8'))} from Topic: {message.topic}")
GVAR = message.payload.decode("utf-8")
global OS_Temp
OS_Temp = float(GVAR)
def on_message2(client, userdata, message):
global OS_Hum
OS_Hum = float(GVAR)
def on_message3(client, userdata, message):
global Pico_Temp
Pico_Temp = float(GVAR)
client.connect(broker, port)
client.on_connect = on_connect
client.on_disconnect = on_disconnect
time.sleep(3)
client.subscribe(topic1)
client.subscribe(topic2)
client.subscribe(topic3)
client.on_message = on_message1
client.on_message = on_message2
client.on_message = on_message3
time.sleep(2)
client.loop_forever()
from MQTT_PW_Vars.py import OS_Temp as PW_Temp
from MQTT_PW_Vars.py import OS_Hum as PW_Hum
from MQTT_PW_Vars.py import Pico_Temp as Pi_Temp
I think you are assigning the client.on_message callback incorrectly. As far as I know only one callback is assigned and the effect of your code it to reassign the callback function, ending up with the on_message3 as being the callback that will be used for all messages received.
The callback function can examine the topics part of the message to decide what function to then call to deal with the data.
So the following could be what you put in your callback function:
or you could create and send mqtt payload data as a delimited string such as "27.3, 22.1, 88.996" where you know the the first data represents the Pico temp and the second represents the os temp etc.
Then you might code it as follows
and in func_to_handle
topics = message.topic.split('/') # topics is now a list containing the topic segments
payload = message.payload.decode()
if topic[1] == "Pico_Temp":
func_to_handle_Pico_Temp(payload)
elif topic[1] == "OS_hum":
func_to_handle_OS_hum(payload)
etc.
if topic[0] == "PicoW":
func_to handle(payload)
def funct_to_handle(pico_data):
pico_temp, os_temp, os_hum = pico_data.split(',')
print('Pico Temperature is: ', pico_temp)
etc.
Regarding imports - study the following
https://realpython.com/python-import/
which should give you a proper understanding of the subject. It may take a while but it will be worth the effort
Hi beetle,
First thank you very much for giving me some of your time to help me try and fix my problem.
You're right in saying that it always appears as though my third message "callback" (if that's what it is) seems to be the master one above all.
It seems to be that no matter what i try to do within the other messages, except for displaying separate readings and topic titles, every thing else gets blended into only the functionality of the third message.
I've spent hours today trying to even get the individual readings sent to separate .txt files so that i can get my main code to get the variables independently via separate .txt files. No such luck. It always lumps them into the one text file, and its always the .txt file opened up in the third message definition logic.
I'm becoming very disheartened over this now. I'm clearly not good enough at trying to do what i want my code to do.
This suggestion of your looks promising.
Where would this code go please?
The code will go into your callback function.
def MyMQTT_Callback():
....the function code
and you nominate this function as your MQTT callback by
client.on_message = MyMQTT_Callback
just as you ended up doing with your client.on_message = on_message3 bit of code. Of course name the function to your desire, on_message3 or MyMQTT_Callback or whatever.
Relating to global variables.
I've been trying to define global variables within functions to a complete loss for some reason.
This is my latest file writing attempt of code:
Why is the result this?:
This is simply doing my head in. This all seems completely logical to me. Yet it refuses to work.
(I should add that there are definitions of files and variables at the top not used now, because i've been hacking a code all day today and it's sometimes bearing previous code attempts)
#!/bin/bash
#MQTT_PW_Vars.py
import datetime
import sys
import os
#initial screen message with delay attached before running program
print("---------------------------------------------------------")
print("---Pico W Receiving Program is loading, please wait...---")
time.sleep(2)
#sleeptimesecs is time setting for program to record samples in secs
sleeptimesecs=10
#program_name = "PicoW_Vars.py"
#readingsfilename1 = 'PicoW_Vars.xls'
#readingsfilename2 = '/home/rissypi/BME280_Envir_Sen/PicoW_Vars.xls'
#PicoSampleFile = 'Pico_Sample.txt'
#PicoMAXFile = 'Pico_MAX.txt'
#PicoMINFile = 'Pico_MIN.txt'
#PicoTempFile = 'PicoTempFile.txt'
#PicoHumFile = 'PicoHumFile.txt'
#PicoFile = 'PicoFile.txt'
#send initial message to terminal to allow quiting later with CTRL+C
current_time = datetime.datetime.now()
time_stamp = current_time.timestamp()
from datetime import datetime
timestamp = time_stamp
date_time = datetime.fromtimestamp(timestamp)
str_date_time1 = date_time.strftime("%d-%m-%Y, %H:%M:%S")
starttimedate1 = str_date_time1
timestamp = time
minsperhour=60
sleeptimemins=sleeptimesecs/minsperhour
#set destination output for printing (original = screen)
orig_out = sys.stdout
loop = 1
sample = 0
loop2 = 1
initial = 0
#MQTT
port = 1883
#keepalive = 120
msg1=False
msg2=False
msg3=False
if rc == 0:
if rc != 0:
time.sleep(3)
def on_message1(client, userdata, message1):
global GVAR11
#global msg1
print(f"Received: {(message1.payload.decode('utf-8'))} from Topic: {message1.topic}")
time.sleep(1)
GVAR1 = str(message1.payload.decode("utf-8"))
GVAR11 = GVAR1
#client.unsubscribe(topic1)
time.sleep(1)
#return GVAR1
def on_message2(client, userdata, message2):
global GVAR22
#global msg2
print(f"Received: {(message2.payload.decode('utf-8'))} from Topic: {message2.topic}")
time.sleep(1)
GVAR2 = str(message2.payload.decode("utf-8"))
GVAR22 = GVAR2
#client.unsubscribe(topic2)
time.sleep(1)
#return GVAR2
def on_message3(client, userdata, message3):
global GVAR33
#global msg3
print(f"Received: {(message3.payload.decode('utf-8'))} from Topic: {message3.topic}")
time.sleep(1)
GVAR3 = str(message3.payload.decode("utf-8"))
GVAR33 = GVAR3
#client.unsubscribe(topic3)
time.sleep(1)
#return GVAR3
while msg1 == False:
time.sleep(3)
PWTfile = open('PicoTempFile.txt', 'w')
PWTfile.write(GVAR11)
PWTfile.close()
msg1 = True
while msg2 == False:
time.sleep(3)
PWHfile = open('PicoHumFile.txt', 'w')
PWHfile.write(GVAR22)
PWHfile.close()
msg2 = True
while msg3 == False:
time.sleep(3)
PicoFile = open('PicoFile.txt', 'w')
PicoFile.write(GVAR33)
PicoFile.write("\n")
PicoFile.close()
msg3 = True
time.sleep(2)
File "/home/rissypi/BME280_Envir_Sen/MQTT_PW_Vars2.py", line 121, in <module>
NameError: name 'GVAR11' is not defined
I'm sorry. I'm not very good at talking the lingo. So a lot of what you said here goes over my head. Can you place your suggestion into my code and paste it back showing me?beetle wrote: ↑Sat Aug 20, 2022 11:51 amThe code will go into your callback function.
Sorry.
Okay, i've had a go at what i think you're suggesting.
This is what i've got:
This produces the result:
It just repeats this now, over and over:
I've made it also print the actual readings, as you can see from what is hashed out now, but ultimately, it never prints out the lines within the if loops!? Therefore it wont also be assigning the global variables etc either (despite the fact that this way of defining global variables doesn't seem to work at all - i'm not sure how else to do it right now!?
Where's it going wrong now please?
#!/bin/bash
#MQTT_PW_Vars4.py
time.sleep(2)
port = 1883
if rc == 0:
if rc != 0:
def on_message(client, userdata, message):
#topics = message.topic.split('/') # topics is now a list containing the topic segments
topics = message.topic.split() # topics is now a list containing the topic segments
print(topics)
#print(topic[1])
payload = message.payload.decode("utf-8")
#print(payload)
if topics == topic1:
global OS_Temp
GVAR = payload
elif topics == topic2:
global OS_Hum
GVAR = payload
elif topics == topic3:
global Pico_Temp
GVAR = payload
time.sleep(3)
time.sleep(2)
['PicoW/Pico_Temp']
['PicoW/OS_Hum']
['PicoW/OS_Temp']
['PicoW/Pico_Temp']
['PicoW/OS_Hum']
['PicoW/OS_Temp']
['PicoW/Pico_Temp']
['PicoW/OS_Hum']
['PicoW/OS_Temp']
Right, i've removed unnecessary complication from my Pico topic strings.
Now just:
topic1 = 'OS_Temp'
topic2 = 'OS_Hum'
topic3 = 'Pico_Temp'
No "/" any more.
Then i've altered my code to this:
This produces this output when i don't try to call my attempted global variables:
So now we're starting to look more promising. It's clearly dipping into the "if topics" conditions now, which is good.
But back to the global variables again. What am I doing wrong there?
This is the result with me trying to print out the global variables at the end to prove they're working (they're not of course):
Now just:
topic1 = 'OS_Temp'
topic2 = 'OS_Hum'
No "/" any more.
#!/bin/bash
#MQTT_PW_Vars4.py
time.sleep(2)
port = 1883
#topic1 = "PicoW/OS_Temp"
#topic2 = "PicoW/OS_Hum"
#topic3 = "PicoW/Pico_Temp"
#topic1 = 'PicoW/OS_Temp'
#topic2 = 'PicoW/OS_Hum'
#topic3 = 'PicoW/Pico_Temp'
topic1 = 'OS_Temp'
topic2 = 'OS_Hum'
if rc == 0:
if rc != 0:
#topics = message.topic.split() # topics is now a list containing the topic segments
#print(topic[1])
#print(payload)
global OS_Temp
GVAR = payload
global OS_Hum
GVAR = payload
global Pico_Temp
GVAR = payload
time.sleep(3)
print(OS_Temp, OS_Hum, Pico_Temp)
time.sleep(2)
Received: 27.0 from Topic: Pico_Temp
Received: 54.7 from Topic: OS_Hum
Received: 24.0 from Topic: OS_Temp
Received: 24.1 from Topic: OS_Temp
File "/home/rissypi/BME280_Envir_Sen/MQTT_PW_Vars4.py", line 72, in <module>
NameError: name 'OS_Temp' is not defined
