Your program whips through the setting up of the mqtt stuf and find a print statement to print a global variable is knows nothing about until a mqtt message arrives. So it complains
Ok, so how do i do it then?beetle wrote: ↑Sat Aug 20, 2022 1:12 pmYour global var only gets set when the on_message function is called (when a mqtt message is received)
Your program whips through the setting up of the mqtt stuf and find a print statement to print a global variable is knows nothing about until a mqtt message arrives. So it complainsand rightly too!
#!/usr/bin/env python
#!/bin/bash
#MQTT_PW_Vars4.py
import paho.mqtt.client as mqtt
#initial screen message with delay attached before running program
print("---------------------------------------------------------")
print("---Pico W Receiving Program is loading, please wait...---")
time.sleep(2)
broker = '192.168.0.51'
port = 1883
mqttclient = "PiLogger"
client = mqtt.Client(mqttclient)
#topic1 = "PicoW/OS_Temp"
#topic2 = "PicoW/OS_Hum"
#topic3 = "PicoW/Pico_Temp"
#topic1 = 'PicoW/OS_Temp'
#topic2 = 'PicoW/OS_Hum'
#topic3 = 'PicoW/Pico_Temp'
topic1 = 'OS_Temp'
topic2 = 'OS_Hum'
topic3 = 'Pico_Temp'
def on_connect(client, userdata, flags, rc):
if rc == 0:
print(f"Connected to MQTT Broker with result: {rc}")
print("Failed to connect to Broker, return code = ", rc)
def on_disconnect(client, userdata, rc):
if rc != 0:
print("Unexpected disconnection!")
msg1set = False
msg2set = False
msg3set = False
def on_message(client, userdata, message):
#topics = message.topic.split('/') # topics is now a list containing the topic segments
#topics = message.topic.split() # topics is now a list containing the topic segments
#print(topic[1])
payload = message.payload.decode("utf-8")
#print(payload)
if topics == topic1:
global OS_Temp
print(f"Received: {(message.payload.decode('utf-8'))} from Topic: {message.topic}")
GVAR = payload
OS_Temp = GVAR
PWTfile = open('PicoTempFile.txt', 'w')
PWTfile.write(OS_Temp)
PWTfile.close()
msg1set=True
return msg1set
if topics == topic2:
global OS_Hum
GVAR = payload
OS_Hum = GVAR
PWHfile = open('PicoHumFile.txt', 'w')
PWHfile.write(OS_Hum)
PWHfile.close()
msg2set=True
return msg2set
if topics == topic3:
global Pico_Temp
GVAR = payload
Pico_Temp = GVAR
PicoFile = open('PicoFile.txt', 'w')
PicoFile.write(Pico_Temp)
#PicoFile.write("\n")
PicoFile.close()
msg3set=True
return msg3set
client.connect(broker, port)
client.on_connect = on_connect
client.on_disconnect = on_disconnect
time.sleep(3)
client.subscribe(topic1)
client.subscribe(topic2)
client.subscribe(topic3)
if msg1set == True:
print("Global OST set: ", OS_Temp)
if msg2set == True:
print("Global OSH set: ", OS_Hum)
if msg3set == True:
print("Global PT set: ", Pico_Temp)
client.on_message = on_message
time.sleep(2)
client.loop_forever()
Thanks for the feedback and your time and patience with me. I appreciate you spending your time writing this feedback to me, i really do.beetle wrote: ↑Sat Aug 20, 2022 2:49 pm"Right , i tried this (at the bottom and inside the if statements). No cigar. Any help"
Not even a quick drag on a ciggy for that amendmentYou are assuming, are you not, that your if the global var is set to True then a print will occur, but the code that sets it to True is, again, only in your on_message function that is not called until a message is received. I think you are assuming your if statements are continually being read. Is this because your mqtt is set to loop forever ? I think this only keeps the mqtt code, which I think runs in a separate thread, running forever, but your main code is just run through the once. If you think about it if all your code is continually looping then you would be trying to set up the mqtt stuff again and again. So you must create an endless loop to poll the if statements to see if the current state of the variables will allow a print() to be made, not just a onetime check.
Your code amendments take you no further than your original with the exception that no attempt is now made to perform the print statement as your code charges through the mqtt setup stuff, then it reaches your if statements, the condition of the variables is False, no print() is done and then your code stops The if statements are never checked again.
Whilst its good to learn python by using some example code, if you do this without getting a few fundamentals under your belt then frustration will be the result. My suggestion, and its meant to be helpful, is to take a little time out to get to grips with a bit more of the basics before ploughing on. I dont think it will take you long, but a weeks worth of slogging at some basic tutorials will see you waltzing though this sort of project to a very different tune. (can you waltz to 'happy days are here again' - well you will probably be bursting into song at the very least)
May I suggst a couple of tutorial resources.
You could try the following beginner youtube tutorials. Get through the fist 9 of this playlist and you will soon be humming a happy tune.
The first episode is here:
https://www.youtube.com/watch?v=YYXdXT2 ... FUiLCjGgY7
also the following is a good on-line read to get to grips with python:
https://thepythoncodingbook.com
import json
# 1. put in your code for connecting to your MQTT broker -
# # assume 'client' is the connection hence client.publish(...) below
# 2. Periodically read your sensors and populate your varialbes with their values
# - eg you end up with something like
temp = 22.4
temp2 = 23.5
hum = 66.44
# 3. Just afer each period read of sensors note the current date and time
# for later putting the data into a CSV file on the rpi.
read_time = time.localtime()
r_time = list(read_time)
if r_time[1] < 10:
r_time[1] = "0" + str(r_time[1])
rD = int(str(r_time[0]) + str(r_time[1]) + str(r_time[2])) #the date in YYYYMMDD format, handy for sorting
rT = str(r_time[3]) + ":" + str(r_time[4]) #the time in Hours:Minutes format
# Serialise the data to publish in the json format
allvaluesJ = json.dumps([rD,rT,temp,temp2,hum])
# print this to have a peek at what you are about to publish (if you desire)
print(allvaluesJ)
# Now publish to data to you broker
client.publish('PicoW/Loft',allvaluesJ)
# now go back to periodically reading your sensors
from paho.mqtt import client as mqtt
import json
import csv
Broker = "10.0.1.141" #put in your MQTT broker IP address
# --------------- Functions to handle MQTT messages received --
def Loft(payload):
# json back to python list
data = json.loads(payload)
# print what we have received for amusement
print(data)
# append the data to a loft_data.csv file
with open('Loft_Data.csv', mode = 'a') as f:
write = csv.writer(f)
write.writerow(data)
# print the date, time and humidity value
print('Humidity at ', data[0], ' ',data[1], ' is ',data[4])
def Outside(payload):
print(payload)
# -------------------- MQTT ----------------------------------
def mqtt_on_connection(client, userdata, flags, rc):
if rc == 0:
client.connected_flag = True # set flag
# print("mqtt_on_connection reports: connected OK")
# subscribe to mqtt topics
client.subscribe('PicoW/Loft')
client.subscribe('PicoW/Outside')
print("MQTT broker is connected ")
print("Bad connection Returned code=", rc)
# print("disconnecting reason " +str(rc))
client.connected_flag = False
print('MQTT is DISCONNECTING')
def mqtt_connect(broker):
# set mqtt
mqtt.Client.connected_flag = False # create flag in class
client = mqtt.Client()
client.on_connect = mqtt_on_connection
client.loop_start()
print("Connecting to broker ", broker)
client.connect(broker)
while not client.connected_flag: # wait in loop
print("Waiting for mqtt broker connection")
time.sleep(2)
return client
except:
print("error initiating MQTT")
# raise error and quit program
# mqtt callback function
def mqtt_on_message(mqttc, userdats, message):
payload = str(message.payload.decode("utf-8"))
if topics == 'PicoW/Loft':
Loft(payload)
elif topics == 'PicoW/Outside':
Outside(payload)
print('message received from a subscrition, but not handled')
# start mqtt
client1 = mqtt_connect(Broker)
# assign callback function
client1.on_message = mqtt_on_message
client1.on_disconnect = on_disconnect
# ------------------ STARTUP ---------------------------------
# program will run forever, use Control C in the terminal to stop it running
pass
Thank you very much for this beetle. I'll have a read through the programs you've offered up to me and see what they're doing by comparison to my own.beetle wrote: ↑Sun Aug 21, 2022 1:16 pmGood to hear you have a running solution and I think you have done very well for such a short time working with Python.
For when you may feel ready to up your python game I give you a couple of programs, one incomplete example to run on your PicoW that sends mqtt data relating to sensor readings and one program that will run on the Raspberry Pi to receive the messages, append the data received to a CSV file (handy for loading the data into a spreadsheet) and has an example of printing the data to the terminal screen. Probably you would later like to expand this to print info to one of the small displays one can get for the rpi. (this rpi program example shows an extra mqtt subscription for, for example, linking in yet another PicoW perhaps reading an outside temperature sensor, mentioned here incase my code confuses)
The program example you could put in your PicoW:
and a program to run on the RPICode: Select all
import json import time # 1. put in your code for connecting to your MQTT broker - # # assume 'client' is the connection hence client.publish(...) below # 2. Periodically read your sensors and populate your varialbes with their values # - eg you end up with something like temp = 22.4 temp2 = 23.5 hum = 66.44 # 3. Just afer each period read of sensors note the current date and time # for later putting the data into a CSV file on the rpi. read_time = time.localtime() r_time = list(read_time) if r_time[1] < 10: r_time[1] = "0" + str(r_time[1]) rD = int(str(r_time[0]) + str(r_time[1]) + str(r_time[2])) #the date in YYYYMMDD format, handy for sorting rT = str(r_time[3]) + ":" + str(r_time[4]) #the time in Hours:Minutes format # Serialise the data to publish in the json format allvaluesJ = json.dumps([rD,rT,temp,temp2,hum]) # print this to have a peek at what you are about to publish (if you desire) print(allvaluesJ) # Now publish to data to you broker client.publish('PicoW/Loft',allvaluesJ) # now go back to periodically reading your sensors
import time from paho.mqtt import client as mqtt import json import csv Broker = "10.0.1.141" #put in your MQTT broker IP address # --------------- Functions to handle MQTT messages received -- def Loft(payload): # json back to python list data = json.loads(payload) # print what we have received for amusement print(data) # append the data to a loft_data.csv file with open('Loft_Data.csv', mode = 'a') as f: write = csv.writer(f) write.writerow(data) # print the date, time and humidity value print('Humidity at ', data[0], ' ',data[1], ' is ',data[4]) def Outside(payload): print(payload) # -------------------- MQTT ---------------------------------- def mqtt_on_connection(client, userdata, flags, rc): if rc == 0: client.connected_flag = True # set flag # print("mqtt_on_connection reports: connected OK") # subscribe to mqtt topics client.subscribe('PicoW/Loft') client.subscribe('PicoW/Outside') print("MQTT broker is connected ") else: print("Bad connection Returned code=", rc) def on_disconnect(client, userdata, rc): # print("disconnecting reason " +str(rc)) client.connected_flag = False print('MQTT is DISCONNECTING') def mqtt_connect(broker): try: # set mqtt mqtt.Client.connected_flag = False # create flag in class client = mqtt.Client() client.on_connect = mqtt_on_connection client.loop_start() print("Connecting to broker ", broker) client.connect(broker) while not client.connected_flag: # wait in loop print("Waiting for mqtt broker connection") time.sleep(2) return client except: print("error initiating MQTT") # raise error and quit program # mqtt callback function def mqtt_on_message(mqttc, userdats, message): topics = message.topic payload = str(message.payload.decode("utf-8")) if topics == 'PicoW/Loft': Loft(payload) elif topics == 'PicoW/Outside': Outside(payload) else: print('message received from a subscrition, but not handled') # start mqtt client1 = mqtt_connect(Broker) # assign callback function client1.on_message = mqtt_on_message client1.on_disconnect = on_disconnect # ------------------ STARTUP --------------------------------- # program will run forever, use Control C in the terminal to stop it running while True: pass
Without the use of global variables in my MQTT subscription code (MQTT_PW_Vars), how can I get OS_Temp, OS_Hum and Pico_Temp out of mybeetle wrote: ↑Mon Aug 22, 2022 11:12 amRissy, I probably did not explain so clearly about the global variables in your program so try this.
Your program starts and sets up a connection to your mqtt broker and makes subscriptions. These instruction go over your wifi and eventually you receive a message relating to your subscriptions. At that point your on-message function and its code springs into action. Before the message received point in time you have just set up what will happen as and when a message is received. Having set up the possibility of what will eventually happen (creating your globals etc), and in computer terms this messaging comms will take a while. The network comms is much much slower then your pico processor which has, the meanwhile, shot passed the setting up of your function on to the bit of your code where you want to print the global variables you function will, eventually, create. Of course these global variable have not yet been created when your program first tries to use them, a few microsecond later maybe, but not yet.
Having said all that, as I hope you can see from my example mqtt receive message program, you don't need any global variables at all, and they are best avoided if you can as if your program grows to cater for all manner of sesnor reads etc. eventually you will trip yourself up to too many globals.
Sound like a good meaty project you have and I expect you will be refactoring your code for a year or two so I would not rush at it. But then I dont rush at much anyway. Now for another cup of tea. Maybe a nap![]()
on_message
from MQTT_PW_Vars import OS_Temp as OS_Temp
