asm_pio error when working in Thonny - Shell
Barbabenno
Post by Barbabenno » Sat Mar 20, 2021 9:20 am
I don't know if this is the right place to report this behaviour, and I also don't know if this behaviour is incorrect, but if I don't report it, it could not be fixed. ;-)
I am trying the example in the 'Get started with MicroPython on Raspberry Pi Pico' book.
When I create a program in a file, it seems to work. But if I start it using the shell, I get an error.
Code:
from rp2 import PIO, StateMachine, asm_pio
@asm_pio(set_init=PIO.OUT_LOW)
def led_quarter_brightness():
    set(pins, 0) [2]
    set(pins, 1)
Error message:
File "<stdin>", line 5, in <module>
File "rp2.py", line 254, in dec
File "<stdin>", line 7, in led_quarter_brightness
NameError: name '__thonny_helper' isn't defined
Software:
  • MicroPython v1.14 on 2021-03-19; Raspberry Pi Pico with RP2040
  • Thonny 3.3.6
Would it be possible to work with the @asm_pio when using the Shell?
aivarannamaa
Re: asm_pio error when working in Thonny - Shell
Post by aivarannamaa » Sun Mar 21, 2021 6:56 am
It looks like Thonny's bug. Please report it at https://github.com/thonny/thonny/issues/new and let's continue our discussion there. Also, please tell your OS, whether you are able to run some other programs and whether you can evaluate expressions in the Shell.
Aivar Annamaa
https://thonny.org
Barbabenno
Post by Barbabenno » Sun Mar 21, 2021 6:34 pm
Thanks for the info.
I submitted an issue with Thonny: https://github.com/thonny/thonny/issues/1718
