I'm trying to write my first PIO program to control stepper motors.
I'd like to be able to tell it how many steps to make and what would be a delay between steps.
After hours and hour of reading docs and watching Youtube videos I'm still not able to write a working program.
Here is what I have so far:
import rp2
@rp2.asm_pio(set_init=rp2.PIO.OUT_LOW)
def stepper():
pull()
mov(x, osr) # delay
pull()
mov(y, osr) # steps
label("step")
set(pins, 1)
label("delay")
set(pins, 0)
# irq(rel(0)) # <- runs continously
jmp(x_dec, "delay")
# irq(rel(0)) # <- only a single invocation
jmp(y_dec, "step")
def turn(sm):
print("irq")
# at 10_000Hz, 1 tick is 100us
sm = rp2.StateMachine(0, stepper, freq=10000, set_base=Pin(25))
sm.irq(turn)
sm.active(1)
sm.put(2)
sm.put(3)
time.sleep(1)
sm.active(0)
1. Read delay between pulses and put it in x
2. Read a number of steps and put it in y
3. Have a loop "step" and iterate until y is zero with "jump(y_dec, "step")"
4. For each step set pin to HIGH and then have a waiting loop for the duration specified in x
I'm invoking an interrupt for debugging and I'm confused by the results.
If I put it inside of the "delay" loop it would just execute continuously until the state machine is stopped. I would expect it to finish after x has become 0.
If I put it inside of the "step" loop it's only executed once. I expected it to be executed 4 times because of sm.put(3)
What am I doing wrong here?
Also, is there a way to keep a copy of x so I can reset it in each "step" back to its original value after it reaches 0?
Cheers,
Leonti
