Raspberry Pico Statemachine Restart
GerryKeely
Post by GerryKeely » Thu Apr 22, 2021 11:53 am
Hi
What is the purpose of the new statemachine restart function in MP 1.15.
A small sample of its use would be appreciated.
Regards & Thank you
Gerry
hippy
Re: Raspberry Pico Statemachine Restart
Post by hippy » Thu Apr 22, 2021 12:44 pm
Looking at the source code it appears to offer the ability to set the execution address of a StateMachine. It effectively allows 'sm.exec("jmp(...)")' though I haven't examined its exact implementation. It seems it may only allow restart from an initial address rather than an arbitrary address as there is no parameter allowed. Thus an example would probably be ...
sm = StateMachine( ... )
# Do things
sm.restart()
Related discussion : https://www.raspberrypi.org/forums/view ... 6&t=308077
Post by Roberthh » Thu Apr 22, 2021 1:00 pm
The intention is to restart the state machine again from the initial address in it#s initial state. That is useful for state machines that stuck in a certain state, e.g. because the input data was incomplete. Then, timeout checking can be done outside the state machine.
A good example is the simplified DHT22 driver in this document; https://github.com/robert-hh/RP2040-Exa ... r/rp2_util, which does no timeout-checking in the state machine code.
The sample code uses the viper version of sm.restart(), but besides that it demonstrates the application.
For jumps to other addresses you can indeed use the sm.exec() method. But since this jump requires a hardcoded address, and that is usually not known in the Python code, it is hardly ever useful.
GerryKeely
Post by GerryKeely » Thu Apr 22, 2021 1:34 pm
Hippy/Roberthh
Thank you both for your prompt replies.
regards
Gerry
