Identifying a special Pico
jcf
Post by jcf » Wed Apr 28, 2021 4:44 pm
From my Python software on the computer I want to identify one special Pico that holds the script for my application, under several different controllers. It seems as if I had a working solution. :D
To better understand why I need this: I have a Pico that controls a DDS generator that should work as standalone device or remotely controlled by computer. The problem with USB devices is that they can always change their device names.
1. step: Identify all the Picos under all devices:
from serial.tools import list_ports
def scan_for_picos():
    '''returns list of connected Raspi Picos'''
    picos = []
    for port in list_ports.comports():
        print("Checking ", port.device)
        if port.manufacturer != None:
            if "MicroPython" in port.manufacturer:
                picos.append(port.device)
    return picos
2. step: from these which one is the right one?
On my Pico I have a file called 'info.py' containing just one function:
def info():
    print( "PICO_2")			# PICO_2 =  name of my Pico
From the computer I do this:
for pico in scan_for_picos():
    info = get_info_pico(pico, 0.5)
    print (pico, '  INFO:  ',   info)
where the function get_info_pico is defined like this:
def get_info_pico(pico, timeout):
    s=serial.Serial(pico, baudrate=115200)
    if s.isOpen()==False:
        s.open()
    # send commands
    s.write(b'\x03\x03')        # Interrupt eventually running program
    s.write(b'\x02')            # Normal REPL
    s.write(b'import info\r')
    s.write(b'info.info()\r')
    # Receive answer (with timeout)
    text = ''
    t1 = time.time()
        nbbytes = s.inWaiting()
        if nbbytes >0:
            c = s.read(nbbytes)
            c = c.decode("utf-8")
            text += c
        if time.time() - t1 > timeout:
            break
    # Analize answer
    if 'Traceback' in text:                 # Something went wrong
        info = ''
    else:                                   # Filter interesting part
        keyword = 'info.info()\r'
        pos1 = text.find(keyword)
        info = text[pos1 + len(keyword):]
        pos2 = info.find('\r')
        info = info[:pos2]
        info = info.strip()
    return info
The result may look like this:
Checking  /dev/ttyS5
Checking  /dev/ttyACM1
/dev/ttyACM0   INFO:   SINGEN
/dev/ttyACM1   INFO:   PICO_2
with the names of the Picos being SINGEN and PICO_2
Sorry for the length of this posting!
hippy
Re: Identifying a special Pico
Post by hippy » Wed Apr 28, 2021 6:16 pm
Instead of importing a module with your .info function, you could create a text file on the Pico, for example run this once -
with open("info.txt", "w") as f:
  f.write("PICO_2")
Then you can have the Pico report what's in that text file -
  with open("info.txt", "r") as f:
    result = f.read().strip()
except:
  result = "Unknown!"
print(result)
scruss
Post by scruss » Wed Apr 28, 2021 8:39 pm
If you're needing the Picos to identify themselves under MicroPython:
import ubinascii
my_id = ubinascii.hexlify(machine.unique_id()).decode()
print(my_id)
This will be a unique hex string for each device.
If you're trying to identify them as connected to a Linux machine, unfortunately /dev/serial/by-id/ doesn't produce different results for different boards. They'll all likely appear as something with the serial number set to '000000000000'
jcf
Post by jcf » Thu Apr 29, 2021 8:03 am
Thanks for the answers!
@hippy
I have thought about a text file, too.
That could be opened from remote by sending open and read commands
The charm of the import solution pleased me however. In the end it may not be simpler. But a good part of my code is to interrupt a running program, receive and analize the answer, and that would be about the same.
@scruss
That's interesting, though it is not exactly what I need. I rather want to find the Pico with the right software than the Pico with the right hardware ID.
jcf
Post by jcf » Thu Apr 29, 2021 9:42 am
I have tried the other variant with a file "info.txt" on the Pico containing just a keyword in the first line (and maybe more text below).
Maybe it is more straightforward than the import variant.
This function on the computer gives the keyword:
def get_info_pico_2(pico, timeout):
    Get info stored on the pico in a file info.txt
        This must contain a keyword in the first line:
        The keyword is returned
        (pico is a port name like '/dev/ttyACM0')
        s.open()
    # send commands
    s.write(b'f = open("info.txt", "r")\r')
    s.write(b't = f.read()\r')
    s.write(b'f.close()\r')
    s.write(b'print(t)\r')
    text = ''
    t1 = time.time()
        if nbbytes >0:
            c = s.read(nbbytes)
            text += c
            break
    # Analize answer
        info = ''
        keyword = 'print(t)'
        info = text[pos1 + len(keyword) +1:]  # keyword found behind print()
        info = info.split()[0]                # take first line only
        info = info.strip()
    return info
As in the above example, you have first to identify the ports with a pico.
To find a special pico, I can use this:
def find_pico(keyword):
        if info == keyword:
            break
    return pico
jcf
Post by jcf » Fri Apr 30, 2021 3:52 pm
Though everything seems to work I am thinking about an improvement by using the Raw REPL
Post by Roberthh » Fri Apr 30, 2021 4:55 pm
There is a PR in the chain for inserting the unique id into the usb id, as being visible in /dev/serial/by-id.
Post by Roberthh » Mon May 03, 2021 7:46 pm
The PR has been merged and should be accessible latest tomorrow in the daily build. Devices are visible then is /dev/serial/by-id e.g. as
usb-MicroPython_Board_in_FS_mode_e66058388340512e-if00
with e66058388340512e being the number returned by machine.unique_id()
jcf
Post by jcf » Wed May 05, 2021 4:23 pm
That's fine.
But as I have already mentioned, I am more interested in identifying a Pico containing the right software than in identifying the hardware.
Anyway, I have learned a lot working on this.
I have summarized my experience here:
http://staff.ltam.lu/feljc/electronics/ ... cation.pdf
scruss
Post by scruss » Thu May 06, 2021 2:04 am
Fair enough. I'd do something like this:
for f in /dev/serial/by-id/usb-MicroPython_*; do ls -la "$f"; ampy --port "$f" ls; echo '----------------------'; done
lrwxrwxrwx 1 root root 13 May  5 21:53 /dev/serial/by-id/usb-MicroPython_Board_in_FS_mode_e66058388375982e-if00 -> ../../ttyACM3
/hello.py
/id.py
/lib
/main.py
lrwxrwxrwx 1 root root 13 Apr 12 15:28 /dev/serial/by-id/usb-MicroPython_Pyboard_Virtual_Comm_Port_in_FS_Mode_336D386B3339-if01 -> ../../ttyACM2
/flash
/sd
If /dev/serial/by-id/usb-MicroPython_Board_in_FS_mode_e66058388375982e-if00 turned out to be the Pico I wanted from its contents, I know it would always show up at that port address
