help required for a newbie
Posted: Sat May 22, 2021 3:45 pm
Can anyone see why the led "led_coming" illuminates before the timer reaches 450? I am new to this and I cant see why it switches on when there appears to be no instruction to do it.
Once adjbell and commutator go high, the normal led should stay on until the timer reaches 450 then it is supposed to go out and the led coming led goes on however, the coming led switches in while the count is still very low.
I would be grateful for any help or suggestions
import utime
# set up LEDs, buttons and switches
bell = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_DOWN)
adjbell = machine.Pin(22, machine.Pin.IN, machine.Pin.PULL_DOWN)
commutator = machine.Pin(15, machine.Pin.IN, machine.Pin.PULL_DOWN)
cancel = machine.Pin(9, machine.Pin.IN, machine.Pin.PULL_DOWN)
sealcancel = machine.Pin(8, machine.Pin.IN, machine.Pin.PULL_DOWN)
led_normal = machine.Pin(12, machine.Pin.OUT)
led_normal.high()
led_coming = machine.Pin(13, machine.Pin.OUT)
led_coming.low()
led_going = machine.Pin(11, machine.Pin.OUT)
led_going.low()
elapsed = 0
# end of setup section
# Normal state
while adjbell.value() == 1:
if elapsed <= 450 and adjbell.value() == 1 and commutator.value() == 1:
elapsed = (elapsed + 1)
print(elapsed)
print("ordinary bell")
print (adjbell.value(),commutator.value())
led_normal.high()
led_coming.low()
if elapsed > 450 and adjbell.value() == 1 and commutator.value() == 1:
print("long bell")
led_coming.high()
