How to read Map() function in micropython?
wael
Post by wael » Fri May 28, 2021 6:57 am
I'm new to micropython.
How to write Map() function in micropython?
In arduino C:
int mappedValue;
int moistureValue = analogRead(A0);
mappedValue = map(moistureValue,AirValue,WaterValue, 0, 100);
How toconvert it into micropython?
How to use the library? I use Thonny but where I can see the examples Arduino ide?
fe2o3
Re: How to read Map() function in micropython?
Post by fe2o3 » Fri May 28, 2021 10:02 am
It's really just simple math.
def map(val, loval, hival, tolow, tohigh):
     if loval <= val <= hival:
         return (val - loval)/(hival-loval)*(tohigh-tolow) + tolow
         raise(ValueError)
You will NEED to verify that (loval < hival) and that (tolow < tohigh)
and return the result in the form you want (int vs float).
A Celsius to Fahrenheit conversion would be as follows:
>>> map(37, 0, 100, 32, 212)
98.6
hippy
Post by hippy » Fri May 28, 2021 2:25 pm
For a simple proportional mapping a single function as given by 'fe203' will suffice.
This is my generic mapping solution ... https://www.raspberrypi.org/forums/view ... 3#p1866943
That handles multiple mappings depending on input value.
Post by pythoncoder » Fri May 28, 2021 5:26 pm
Bear in mind that map is a Python keyword (with different functionality).
SpotlightKid
Post by SpotlightKid » Sun May 30, 2021 8:26 pm
It's actually a built-in function (or rather a class acting like a function), which means you can use "map" for identifiers without getting a syntax error. You will then of course shadow the builtin function.
Post by pythoncoder » Mon May 31, 2021 5:28 am
Indeed, it will work. But in my opinion it is not pretty and may confuse anyone reading the code.
fe2o3
Post by fe2o3 » Mon May 31, 2021 8:38 am
I'd probably just rename map() to rescale(). The map(), as described
by the op, reminds me of the map function from Parallax BASIC for
their Stamp controllers.
-Rusty-
scruss
Post by scruss » Mon May 31, 2021 7:20 pm
we already did this last year: map function
for floats, a modification of the old code from Processing that Wiring/Arduino inherited will do:
def valmap(value, istart, istop, ostart, ostop):
  return ostart + (ostop - ostart) * ((value - istart) / (istop - istart))
Not if you're extrapolating, which is often more useful than stopping with an exception.
For this reason, Arduino also provides the constrain() function if you want to keep the output range constrained
OlivierLenoir
Post by OlivierLenoir » Tue Jun 01, 2021 4:55 am
You can also read this.
Jackli
Post by Jackli » Tue Jun 01, 2021 7:50 am
This is very helpful, thanks a lot!
