RB pi Pico and MCP4728 DAC
Posted: Tue Jun 01, 2021 10:53 pm
by Andre
Hi there!
I'm trying to connect a Pico to a MCP4728 adafruit I2C 12-bit quad DAC, but I'm not being able to.
So far I have 4 ADC sensors, ADC(4) with the onbard temperature, ADC(0), ADC(1), ADC(2) with pressure sensors.
Can anyone help me?
import struct
from mcp4728 import MCP4728
from mcp4728 import Channel
_MCP4728_DEFAULT_ADDRESS = 0x60
_MCP4728_CH_A_MULTI_EEPROM = 0x50
i2c_bus = 0x0
oil_sensor = machine.ADC(26)
gas_sensor = machine.ADC(27)
water_sensor = machine.ADC(28)
oil = oil_sensor.read_u16()
gas = gas_sensor.read_u16()
water = water_sensor.read_u16()
temp_sensor = machine.ADC(4)
temperature = temp_sensor.read_u16()
LED = machine.Pin(25, machine.Pin.OUT)
i2c = machine.I2C(0, scl=machine.Pin(9), sda=machine.Pin(8), freq=400000)
dac = MCP4728(i2c, 0x60)
LED(1)
print(oil, " oil integral") #oil valor lido pelo sensor em integral
to_volts = 0.5 / 10562
oil_2 = oil * to_volts #oil valor convertido para volts
print(round(oil_2,1), "oil volts")
oil_bar = 2.59 * oil_2 - 1.29 #oil valor convertido para BAR
print(round(oil_bar,1), "oil BAR")
print('_____________')
print(gas, "gas integral") #gas valor lido pelo sensor em integral
gas_2 = gas * to_volts #gas valor convertido para volts
print(round(gas_2,1), "gas volts")
gas_bar = 2.59 * gas_2 - 1.29 #gas valor convertido para BAR
print(round(gas_bar,1), "gas BAR")
print(water, "water integral") #water valor lido pelo sensor em integral
water_2 = water * to_volts #water valor convertido para volts
print(round(water_2,1), "water volts")
water_bar = 2.59 * water_2 - 1.29 #water valor convertido para BAR
print(round(water_bar,1), "water BAR")
to_volts_temp = 3.3 / 65535
temperature_2 = temperature * to_volts_temp
celsius_degrees = 27 - (temperature_2 - 0.706) / 0.001721
print(round(celsius_degrees,1), "C")
dac.a.value=int(round(oil_bar,0))
dac.b.value=int(round(gas_bar,0))
dac.c.value=int(round(water_bar,0))
dac.d.value=int(celsius_degrees)
print(dac.a.value, "oil")
print(dac.b.value, "gas")
print(dac.c.value, "water")
print(dac.d.value, "C")
print("__________________________________")
LED(0)
time.sleep(10)
