Save recorded data to .txt file
james_saunders2
Post by james_saunders2 » Mon Jun 21, 2021 9:58 am
I'm looking for a way to save data that I have stored into an array on the Raspberry Pi Pico using Thonny into a .txt file on my computer so that I can access it. This is the code I am using:
from utime import sleep, ticks_ms, ticks_diff
# This code reads the serial data and assigns it to an array which then sends it to a .txt file after
analog_value = machine.ADC(26) # Assign pin 26 to the input
reading = [None] * 20000 # Setup array of 20,000 elements for 20,000 recordings
timer_start = ticks_ms() # Just used to check how long the recording takes
for i in range(20000):
    reading[i] = analog_value.read_u16() # Takes down ADC output value
time_difference = ticks_diff(ticks_ms(), timer_start) # Stops and prints timer value
print("Recording time: " + str(time_difference) + " miliseconds.")
file = open("microphone_readings.txt", "w")
timer_start = ticks_ms() # Just to check how long printing to the .txt file takes
    file.write(str(reading[i]) + "\n") # Writes readings to .txt fie saved on Pico
    file.flush
print("Print time: " + str(time_difference) + " miliseconds.")
Basically, the issue is that it saves the data to the Pi Pico, but I need to be able to access and plot the data which I can't think how to do from the Pico, and I can't see a way of saving that data to the computer instead.
Any ideas?
scruss
Re: Save recorded data to .txt file
Post by scruss » Wed Jun 23, 2021 12:11 am
You could:
  • write the file to an SD card, and look at that in your computer later
  • print the data to the serial connection, and capture that to a local file using something like grabserial
Post by dhylands » Wed Jun 23, 2021 2:24 am
I wrote json-ipc which you could use to transfer the data the your host and then plot it from there.
https://github.com/dhylands/json-ipc
Christian Walther
Post by Christian Walther » Wed Jun 23, 2021 7:12 pm
If a permanent serial connection to your computer is acceptable, you can use mpremote to mount a directory from your computer on the Pico. If not, just use it (or any other file transfer tool) to copy the file over.
