Thanks.
But am not convinced. But I will take this to the development forum, since it is about a change to micropython documentation and not a question about a raspberry pi-specific question.
Trivial code sometimes takes 5ms and interrupts are missed
Re: Trivial code sometimes takes 5ms and interrupts are missed
Depending of your time resolution you want you are restricted with gc and the clock of the cpu and the code in your loop.
Hardware interrupt is a most for time critical operation.
B.T.W. Setting the cpu at 250Mhz and it works just fine! The Garbage collector and the floating point operation are fast enough for your millisecond accuracy.
machine.freq(250000000)
