Low frequency Signal generator for CTCSS
Re: Low frequency Signal generator for CTCSS
Looks reasonable to me!
Just to close off. I tested this in my code with all the other timers and it is working as predicted. A steady output with an accurate frequency.
One concern I had was rounding errors in the calculations and clock divisions, so I did another experiment by upping the frequency and dividing down by 500 to see if I could see any difference in precision while monitoring the output with a frequency counter. I found that I couldn't really see any difference between 100 x and 500x , so I guess the accuracy must be better +- 0.05%
Good enough for what I need.
Many thanks for everyone's help.
Cheers
Cheers
But that's simply because the .freq(hz) implementation doesn't accept anything other than an integer argument. Allow it to accept float and integer and it does just fine -- within the limits of rounding errors and hardware limitations.
The current Pico implementation of .freq(hz) is completely wacko, often doesn't generate the frequencies one has asked for, so perhaps support for float values could be added when that gets fixed.
https://www.raspberrypi.org/forums/view ... 1#p1895341
The PWM hardware can do more that what MP limits us to.
From the RP2040 datasheet, section 4.5.2.6, the output frequency is:
(ignoring the phase correct flag and fractional divider)
Write a quick program and brute-force search for the output you want.
For the 76.7 tone:
And that's using only the integer divider, ignoring the fractional part.
The major source of error would be the crystal, yes?
fpwm = 125MHz / (top + 1) / div_int
For the 76.7 tone:
div top fpwm
42 38802 76.7000
25 65188 76.7001
47 34674 76.7001
73 22324 76.7001
95 17154 76.7001
Here's a table of divider and top values for each of the tones.
CTCSS tones 50
div top freq fpwm diff
101 18471 67.0000 67.0000 -0.0000
46 39211 69.3000 69.3000 -0.0000
89 19533 71.9000 71.9000 -0.0000
31 54196 74.4000 74.4000 0.0000
31 52366 77.0000 77.0000 -0.0000
103 15226 79.7000 79.7000 0.0000
181 8370 82.5000 82.5000 0.0000
25 58547 85.4000 85.4000 0.0000
23 61409 88.5000 88.5000 -0.0000
34 40179 91.5000 91.5000 0.0000
26 50713 94.8000 94.8001 0.0001
59 21751 97.4000 97.4000 -0.0000
20 62499 100.0000 100.0000 0.0000
31 38958 103.5000 103.5000 0.0000
101 11544 107.2000 107.2000 -0.0000
27 41745 110.9000 110.9000 -0.0000
17 64049 114.8000 114.8000 0.0000
47 22386 118.8000 118.7999 -0.0001
17 59779 123.0000 123.0000 0.0000
28 35068 127.3000 127.3001 0.0001
227 4177 131.8000 131.8001 0.0001
185 4949 136.5000 136.5001 0.0001
131 6752 141.3000 141.2999 -0.0001
14 61070 146.2000 146.1999 -0.0001
127 6500 151.4000 151.4001 0.0001
29 27506 156.7000 156.6999 -0.0001
167 4683 159.8000 159.8000 -0.0000
13 59280 162.2000 162.2001 0.0001
13 58098 165.5000 165.5000 0.0000
53 14046 167.9000 167.8999 -0.0001
19 38405 171.3000 171.3000 -0.0000
157 4580 173.8000 173.8001 0.0001
20 35250 177.3000 177.2999 -0.0001
15 46321 179.9000 179.9001 0.0001
14 48656 183.5000 183.5002 0.0002
29 23148 186.2000 186.2000 0.0000
71 9270 189.9000 189.9001 0.0001
10 64833 192.8000 192.8001 0.0001
12 52983 196.6000 196.6002 0.0002
23 27241 199.5000 199.5001 0.0001
19 32328 203.5000 203.4999 -0.0001
173 3498 206.5000 206.5000 -0.0000
10 59325 210.7000 210.7002 0.0002
14 40937 218.1000 218.0998 -0.0002
21 26372 225.7000 225.6998 -0.0002
17 32094 229.1000 229.0993 -0.0007
16 33443 233.6000 233.5994 -0.0006
11 46995 241.8000 241.8001 0.0001
9 55488 250.3000 250.2999 -0.0001
14 35137 254.1000 254.1002 0.0002
A better sine approximation can be done with two PWM outputs. The PWM frequency is 6 times the resulting sine wave frequency, which means the first overtone for the "sine" is 6x the frequency, so it's easier to filter. Use the up/down mode, and set the PWM levels to 1/3 and 2/3. Sum the outputs with equal value resistors to get a stepped approximation. Use machine.mem32 to poke the registers after MP configures it.
You get something like this:
And here's the table of best dividers and top values for the tone frequencies x 6. Higher frequency so a little more error.
pwm A __--__
pwm B _----_
sum _-''-_ two low, mid, two high, mid
CTCSS tones 50
6x freq phase-correct
3 51823 402.0000 402.0016 0.0016
83 1810 415.8000 415.7990 -0.0010
23 6298 431.4000 431.4004 0.0004
4 35001 446.4000 446.4031 0.0031
7 19325 462.0000 461.9979 -0.0021
2 65348 478.2000 478.2017 0.0017
31 4072 495.0000 494.9985 -0.0015
5 24394 512.4000 512.4001 0.0001
2 58850 531.0000 531.0020 0.0020
2 56921 549.0000 548.9969 -0.0031
2 54939 568.8000 568.8023 0.0023
3 35648 584.4000 584.4016 0.0016
7 14880 600.0000 599.9981 -0.0019
2 50321 621.0000 621.0008 0.0008
2 48584 643.2000 643.2026 0.0026
2 46963 665.4000 665.4033 0.0033
2 45368 688.8000 688.7963 -0.0037
2 43840 712.8000 712.8031 0.0031
2 42343 738.0000 738.0030 0.0030
2 40913 763.8000 763.7972 -0.0028
2 39516 790.8000 790.7989 -0.0011
17 4488 819.0000 818.9955 -0.0045
2 36859 847.8000 847.8025 0.0025
2 35624 877.2000 877.1930 -0.0070
3 22933 908.4000 908.4038 0.0038
5 13294 940.2000 940.2031 0.0031
1 65185 958.8000 958.7948 -0.0052
3 21406 973.2000 973.2019 0.0019
1 62940 993.0000 992.9934 -0.0066
7 8862 1007.4000 1007.3983 -0.0017
1 60808 1027.8000 1027.8084 0.0084
1 59934 1042.8000 1042.7964 -0.0036
1 58751 1063.8000 1063.7936 -0.0064
1 57902 1079.4000 1079.3914 -0.0086
1 56766 1101.0000 1100.9918 -0.0082
1 55942 1117.2000 1117.2086 0.0086
1 54852 1139.4000 1139.4090 0.0090
1 54027 1156.8000 1156.8076 0.0076
1 52983 1179.6000 1179.6014 0.0014
1 52213 1197.0000 1196.9970 -0.0030
1 51187 1221.0000 1220.9893 -0.0107
1 50443 1239.0000 1238.9977 -0.0023
1 49437 1264.2000 1264.2097 0.0097
7 6822 1308.6000 1308.5991 -0.0009
1 46152 1354.2000 1354.1915 -0.0085
1 45467 1374.6000 1374.5931 -0.0069
1 44591 1401.6000 1401.5967 -0.0033
1 43079 1450.8000 1450.7892 -0.0108
1 41616 1501.8000 1501.7901 -0.0099
1 40993 1524.6000 1524.6134 0.0134
For accurate musical tones, 2-bit sine wave generation, one would be better off ignoring PWM and implementing a frequency generator using a PIO.
There is an example of that here - https://www.raspberrypi.org/forums/view ... 5#p1902085 - which is part of a thread on improving the pwm.freq() implementation and creating accurate PWM frequencies.
Accurate how? Spectra or pitch? You saw the errors - one thousandth of a Hertz difference isn't going to affect the CTCSS tone detection.For accurate musical tones,
And if you really have to go the PIO route, you can drive 4 outputs to get a 5-level sine approximation, with the first overtone at 10x the base frequency. There's articles out there about Johnson walking ring counters to make sine waves. It's also in The Art of Electronics.
