Print message when same button is pressed
soggycashew
Post by soggycashew » Sat Sep 25, 2021 1:10 am
Hello, What I'm trying to do is I have two buttons and a active buzzer. If I press B1 I need it to Print("Goto button 2") and I would proceed to B2 and it would print Print("Goto button 1") and all is good BUT here is my issue.
If I press B1 and then I press B1 again I need to Print("Error you double pressed button 1") and
sound the active buzzer for 3 seconds and print Print("Goto button 2").
If I press B2 and then I press B2 again I need to Print("Error you double pressed button 2") and
sound the active buzzer for 3 seconds and print Print("Goto button 1").
How can I do this? The code below I put together from the web and all it does is print when I press either button and I can hold down the buttons and it will only print 1 time with each press.
import utime
B1 = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_DOWN)
B2 = machine.Pin(15, machine.Pin.IN, machine.Pin.PULL_DOWN)
buzzer = machine.Pin(12, machine.Pin.OUT)
B1_last_state = False
B1_current_state = False
B2_last_state = False
B2_current_state = False
    B1_current_state = B1.value()
    if B1_last_state == 0 and B1_current_state == 1:
        print("You pressed button 1)
        utime.sleep(0.25)
    B1_last_state = B1_current_state
    B2_current_state = B2.value()
    if B2_last_state == 0 and B2_current_state == 1:
        print("You pressed button 2")
        utime.sleep(0.25)
    B2_last_state = B2_current_state
davef
Re: Print message when same button is pressed
Post by davef » Sat Sep 25, 2021 1:33 am
I'd try using a counter on the button states.
And some more if ... else statements.
fdufnews
Post by fdufnews » Sat Sep 25, 2021 7:23 am
The program needs to remember wich button was previously pressed.
And you then compare the currently one and the previous and if it matches you print an error.
So, when a button is pressed you put the button number in a variable for later use.
soggycashew
Post by soggycashew » Sat Sep 25, 2021 2:40 pm
Im a beginner can you give an example to start from?
Thanks,
hippy
Post by hippy » Sat Sep 25, 2021 3:49 pm
Replace
print("You pressed button 1")
With something like -
if last_pushed == 1:
  print("You pressed button 1 again")
elif last_pushed == 2:
  print("You pressed button 1 after pressing button 2")
last_pushed = 1
Add similar for the other button, initialise last_pushed to zero.
cnmcdee
Post by cnmcdee » Sat Sep 25, 2021 9:00 pm
Sounds like a fun problem, there are LOTS of ways to code this however you want to groom your logic so it behaves.
Here is a simple toggle example:
import utime
def nasty_buzzer():
	print("nasty buzzer")
	# I think the standard tutorial on a buzzer is milliseconds on / milliseconds off..
	# I'll leave it for someone if they want to look it up.
button1_counter = 0
button2_counter = 0
if B1.value(): # was the B1 button pushed?
	button1_counter += 1
	button2_counter = 0   # Force the toggle (reset the other side)
	if button1_counter % 2 == 1:  # Message head to button 2 on odd pushes
		print("Goto Button 2")
	if button1_counter %2 == 0:  #Pushed it twice kick to buzzer
		print("You double pressed Button 1!")
		nasty_buzzer()
		print("Goto Button 2!")
if B2.value():  # Was the B2 button pushed?
	button2_counter += 1
	button1_counter = 0 # Force the toggle (reset the other side)
	if button2_counter %2 == 1:  # Message head to button 0 on odd pushes
		print("Goto Button 1")
		print("You double pressed Button 2!")
		nasty_buzzer()
		print("Goto Button 1!")
This logic block will toggle between "Goto button X" and Buzzer. If you want it to latch to buzzer indefinitely after the second push it would be:
	if button2_counter == 1: # Message head to button 0 on the first push
	if button2_counter > 1:  # Buzzer here on in.
		nasty_buzzer()
soggycashew
Post by soggycashew » Sat Sep 25, 2021 9:15 pm
Thank you so much guys/gals I cant wait to get home ant try this! If i were to have another button B3 that could turn off the buzzer when it goes off is that doable?
On a side note thank you for the #comments so i know how its working, I been searching the web for a few weeks and cant find anything pertaining to my scenario. Is there a book of examples i can get pertaining to the pico and micropython? I do have the book getting started with micropython on the Pico but it's kind of vague.
Thanks!
cnmcdee
Post by cnmcdee » Sat Sep 25, 2021 9:28 pm
buzzer_enabled = True
def nasty_buzzer():
	if buzzer_enabled:
		print("Nasty buzzer")
if button3.value():  # Silence your buzzer.
	buzzer_enabled = False
soggycashew
Post by soggycashew » Sun Sep 26, 2021 12:27 am
UPDATE: I added a while True and a pause then tabbed everything over once and ran and it ran! I'm so excited, I finally have a starting point! I keep looking at the code and basically from what I'm getting is your passing a 1 or 0 around and if its a 1 its pressed and 0 is not pressed.
Is there a good tutorial I can read? Or a book I should get? I would love to learn a little bit more with buttons etc. I would also like to know what the % represents?
% 2 == 1
Here is what I added is it correct? Thanks
import utime
def nasty_buzzer():
button1_counter = 0
button2_counter = 0
            utime.sleep(0.25)
            nasty_buzzer()
            utime.sleep(0.25)
    if B2.value(): # was the B2 button pushed?
        if button2_counter % 2 == 1:  # Message head to button 1 on odd pushes
            utime.sleep(0.25)
        if button2_counter %2 == 0:  #Pushed it twice kick to buzzer
            nasty_buzzer()
            utime.sleep(0.25)
