Multicore FIFO
torpi
Multicore FIFO
Post by torpi » Mon Nov 01, 2021 6:56 pm
Hello everyone,
I am wondering if we can access the multicore FIFO so thread one on core 0 could send data to thread 2 on core 1?
Basically, the equivalent of the C++ SDK (here) multicore_fifo_push_blocking() and multicore_push_pop_blocking() would do the job but I cannot find anything similar in the MicroPython documentation.
Thank you very much,
Torpi
Re: Multicore FIFO
Post by pythoncoder » Tue Nov 02, 2021 9:14 am
You may be breaking new ground with this one, but it's a problem well worth solving. It is easy to make a FIFO in Python but I guess the concern is about thread safety. Would it be possible to use a structure with inherent thread safety such as a ring buffer? Could something clever be done with the PIO?
[EDIT]
Why not use the lock object? The following seems to work, calculating Fibonacci numbers on one core and printing them on the other:
import _thread
from time import sleep_ms
lock = _thread.allocate_lock()
def other(d):
        lock.acquire()
        n = d[0]
        l = d[1]
        q = l[n] + l[n -1]
        d[1].append(q)
        d[0] += 1
        lock.release()
        sleep_ms(100)
def main():
    d = [1, [1, 1]]
    _thread.start_new_thread(other, (d,))
        lock.acquire()
        print(d)
        lock.release()
        sleep_ms(103)
main()
torpi
Re: Multicore FIFO
Post by torpi » Tue Nov 02, 2021 1:52 pm
Hello and thank you pythoncoder!
I first thought of locking mechanisms but my understanding was that Queue() has a thread-safe implementation with all the required locking mechanism and I could basically pass a queue as an argument to the second thread:
In Main:
q = queue.Queue()
_thread.start_new_thread(second_core_thread, (q) )
msg = q.get()
In second_core_thread:
def writer(q):
queue.put(....)
What I was thinking is leveraging the two FIFO buffers of the RP2040 so I can squeeze out all the juice of the Pico. My understanding is that I need to go C/C++ for that since uPython does not yet offer it, is that a good assumption?
The image comes from this site
Re: Multicore FIFO
Post by pythoncoder » Wed Nov 03, 2021 11:01 am
As far as I know that is true. You may achieve results by doing register level coding in Python using machine.mem32 and uctypes.addressof.
I'd suggest that it is only a subset of Python applications which will receive a significant performance boost using hardware FIFOs compared to a shared data structure. The golden rule of any optimisation is to identify where the bottleneck actually is.
torpi
Re: Multicore FIFO
Post by torpi » Wed Nov 03, 2021 12:16 pm
Thank you for your message @pythoncoder!
100% with you on this one.
hippy
Re: Multicore FIFO
Post by hippy » Sat Nov 06, 2021 4:38 pm
That should work and I have had success using 'mem32' to directly interact with RP2040 registers, but I saw some odd behaviour when I tried that with the Inter-Core FIFO. Results were inconstant and varied depending on sequence of what was done and values pushed to the FIFO.
For example, when nothing should be running on the second core, I am able to read two items with 'get', and was able to 'put' 15 items to the FIFO -
Get test
Get 0
Get 0
Blind Put test
Put 3203334144
Put 3203334145
Put 3203334146
Put 3203334147
Put 3203334148
Put 3203334149
Put 3203334150
Put 3203334151
Put 3203334152
Put 3203334153
Put 3203334154
Put 3203334155
Put 3203334156
Put 3203334157
Put 3203334158
  File "<stdin>", line 59, in <module>
  File "<stdin>", line 31, in put
Exception: put when not ready
Test code at the time ...
# intercore.py
from machine import mem32
# Register Base Addresses
SIO_BASE            = 0xD0000000
# Processor ID
CPUID               = SIO_BASE + 0x000
# Inter-core FIFO - 8 words deep
FIFO_STATUS         = SIO_BASE + 0x050
FIFO_WR             = SIO_BASE + 0x054
FIFO_RD             = SIO_BASE + 0x058
FIFO_STATUS_ROE_BIT = 3 # Was read when empty - 1=Yes (sticky)
FIFO_STATUS_WOF_BIT = 2 # Was write when full - 1=Yes (sticky)
FIFO_STATUS_RDY_BIT = 1 # Can write to fIFO   - 1=Yes
FIFO_STATUS_ANY_BIT = 0 # Can read from FIFO  - 1=Yes
def rdy():
    return (mem32[FIFO_STATUS] >> FIFO_STATUS_RDY_BIT ) & 1
def put(n):
    if rdy():
        mem32[FIFO_WR] =  n
        raise Exception("put when not ready")
    return n
def any():
    return (mem32[FIFO_STATUS] >> FIFO_STATUS_ANY_BIT ) & 1
def get():
    if any():
        return mem32[FIFO_RD]
        raise Exception("get when none available")
if __name__ == "__main__":
    n = 0xBEEF_0000
    if True:
        print("Blind Get test")
           print("Get {:x}".format(get()))
    elif True:
        print("Get test")
            if any():
    elif True:
        print("Blind Put test")
            print("Put {:x}".format(put(n)))
            n += 1
    elif True:
        print("Put test")
            if rdy():
                n += 1
       print("Put and Get test")
            if rdy():
                n += 1
            while any():
Re: Multicore FIFO
Post by pythoncoder » Sat Nov 06, 2021 6:22 pm
I'm getting odd results with dual core coding when accessing a hardware resource (in my case a UART). I think there's a bug lurking somewhere.
torpi
Re: Multicore FIFO
Post by torpi » Mon Nov 08, 2021 7:23 pm
I can confirm I am also getting odd results on my side.
Torpi
hippy
Re: Multicore FIFO
Post by hippy » Sun Dec 05, 2021 6:32 pm
A belated update. I created a C Extension Module which allows access to the inter-core FIFO using the standard Pico SDK methods, nothing complicated, nothing out of the ordinary -
STATIC mp_obj_t core1_put(mp_obj_t int_obj) {
    multicore_fifo_push_blocking(mp_obj_get_int(int_obj));
    return mp_const_none;
MP_DEFINE_CONST_FUN_OBJ_1(core1_put_obj, core1_put);
STATIC mp_obj_t core1_get(void) {
    return mp_obj_new_int(multicore_fifo_pop_blocking());
MP_DEFINE_CONST_FUN_OBJ_0(core1_get_obj, core1_get);
Without anything explicitly started on the second core, it is behaving as oddly as it was when I tried via registers using 'mem32'; I can 'get' at least one zero, and I can 'put' more than eight items. When I 'put' things it seems I can 'get' more things back.
It all suggests to me something is interacting with the FIFO, something in MicroPython (1.17-220) or something from Pico SDK (1.3), or there is something broken somewhere.
Unless the core can read its own FIFO, and the hardware definition indicates it cannot, something on the other core must be running, but I can't see how it is, or where that would be being launched.
I set "#define MICROPY_PY_THREAD (0)" in 'mpconfigport.h' but same result. Looking through the '.dis' file I can't see anywhere anything is linking to "multicore_*", any indication MicroPython itself is using it.
I guess the next thing to do is see if a Pico SDK C program exhibits the same behaviour.
Update : Easier than I thought. Same odd behaviour so I'll chase that up on the Raspberry Pi forum.
hippy
Re: Multicore FIFO
Post by hippy » Mon Dec 06, 2021 5:26 pm
Mystery solved
As part of booting, Core 1 runs a program implementing a 'launch protocol' via the FIFO which allows something else to be launched on Core 1.
What I was seeing was interaction with that program, it reading the FIFO, filling the return FIFO, when I didn't think anything was or would be running on Core 1.
So, the lesson is, don't interact with the FIFO unless your own code is running on Core 1.
