Raspberry pi pico NEMA34 Stepper
Posted: Thu Nov 04, 2021 2:36 pm
by berke
Hello everyone. I bought NEMA34 nad CS-D808 driver (30V-80V) . I asked him can I run this with 24V and he says yes but now it isn't working. Is it to code or is it because vol is not enough? Here is my code
import utime
dirPin = Pin(4, Pin.OUT)
stepPin = Pin(3, Pin.OUT)
enaPin = Pin(2, Pin.OUT)
dirPin.high()
    stepPin.high()
    time.sleep_us(200)
    stepPin.low()
    time.sleep_us(200)
I connected DIR- , PUL- , ENA- to GND. I connected DIR+ to pin 4 ,PUL+ to pin 3, ENA+ to pin 2 .
Is this code correct?
Can I run this with 24V-6A ? Top of the driver, It says (VDC 30V-80 V)
Re: Raspberry pi pico NEMA34 Stepper
Posted: Thu Nov 04, 2021 4:39 pm
by OlivierLenoir
The CS-D808 datasheet says page 6, min operating voltage 30V, typical 48V to 60V, max 80V.
The enable pin should be high to work, page 8.
Posted: Thu Nov 04, 2021 6:43 pm
by berke
Thank you. I will try to find at least 30V 6A tomorrow. I hope, power is the problem. I will ise enaPin.high() . This code is seems so simple. Is this code true? I converted from arduino TB6600 driver.
Posted: Fri Nov 05, 2021 12:02 pm
by berke
I found the problem. I didn't connected Encoders cable but Closed Loop motors encoders pins should be connected. I connected encoder cables and it is working now. Thank you everyone.
