TOF VL53L0X
soggycashew
TOF VL53L0X
Post by soggycashew » Fri Dec 03, 2021 12:21 am
Hello, I wanted to play around with the TOF sensor so I bought THIS ONE. I connected the power to 3v3, ground, SCL and SDA and ran the code below. I get an error:
File "<stdin>", line 17, in <module>
OSError: [Errno 5] EIO
which line 17 is i2c.readfrom_mem_into(addr, 0, data).
i2c = I2C(0, sda=machine.Pin(0), scl=machine.Pin(1), freq=100000)
addr = i2c.scan()[0]
data = bytearray(2)
    distance = data[0] << 8 | data[1]
    print(distance)
Thoughts?
scruss
Re: TOF VL53L0X
Post by scruss » Fri Dec 03, 2021 3:02 am
Thoughts?
I think you need a library: either uceeatz/VL53L0X: Micropython Library for Lidar Sensor VL53L0X or mcauser/deshipu-micropython-vl53l0x.
(another plug for Awesome MicroPython)
soggycashew
Re: TOF VL53L0X
Post by soggycashew » Fri Dec 03, 2021 8:00 am
I got it working with Kevin McAleers github files and his YouTube tutorial on the VL5310X
https://github.com/kevinmcaleer/vl53l0x
soggycashew
Re: TOF VL53L0X
Post by soggycashew » Fri Dec 03, 2021 2:31 pm
It works as in gives readings but they are not very accurate. Any other librarys out there?
