Pico and BNO055 IMU
Re: Pico and BNO055 IMU
Post by pythoncoder » Sat Jan 15, 2022 9:52 am
It isn't as clear-cut as that. Please see this GitHub issue. According to one of the CircuitPython lead developers the hardware does support clock stretching. The cause of the actual problem is being studied.
As a practical workround the one I described above is fine.
Nitrosfpv
Post by Nitrosfpv » Sat Jan 15, 2022 2:24 pm
scruss wrote:
Sat Jan 15, 2022 1:24 am
Except there won't be one for hardware I2C, because the BNO055 IMU requires clock stretching, something the Pico's hardware I2C doesn't support
Where did you get this assumption from?
- nothing is really written about it on the data sheet.
https://datasheets.raspberrypi.com/rp20 ... asheet.pdf
Post by pythoncoder » Sun Jan 16, 2022 5:11 pm
This was my guess as to the cause of the fault. It proved incorrect. Hard I2C can be fixed with this patch.
Nitrosfpv
Post by Nitrosfpv » Mon Jan 17, 2022 4:43 pm
Very well.
When I have a Pi again I will compile and test the patch.
fivdi
Re: The verdict
Post by fivdi » Fri Feb 04, 2022 1:40 pm
pythoncoder wrote:
Wed Jan 12, 2022 10:00 am
As for CircuitPython it is aimed at users with less technical knowledge. As such it loses the most interesting features of MicroPython such as interrupts and asynchronous coding, but it gains in "plug and play" ease of use.
The response is a little late but CircuitPython 7.1.0 added support for asynchronous coding. For further details, see Cooperative Multitasking in CircuitPython with asyncio.
Post by pythoncoder » Sat Feb 05, 2022 6:05 am
Excellent :)
