Pico and BNO055 IMU
Thomas_G_S
Pico and BNO055 IMU
Post by Thomas_G_S » Mon Jan 03, 2022 1:37 pm
Hello
I'm trying to get my Raspberry Pi Pico to collect data from the adafruit BNO055 IMU breakout using Micropython. So far I have this code:
import adafruit_bno055
i2c = machine.I2C(0, scl=machine.Pin(1), sda=machine.Pin(0))
sensor = adafruit_bno055.BNO055_I2C(i2c)
print(sensor.temperature)
print(sensor.euler)
print(sensor.gravity)
and I am getting this error message:
File "<stdin>", line 5, in <module>
File "/lib/adafruit_bno055.py", line 768, in __init__
File "/lib/adafruit_bus_device/i2c_device.py", line 50, in __init__
File "/lib/adafruit_bus_device/i2c_device.py", line 152, in __probe_for_device
AttributeError: 'I2C' object has no attribute 'try_lock'
can anyone help me?
Re: Pico and BNO055 IMU
Post by Roberthh » Mon Jan 03, 2022 5:14 pm
The Adafruit dialect of MicroPython called CircuitPython is different from the genuine MicroPyhon. If you want to use Adafruit drivers, it may be easier to use CircuitPython as well for your board.
sonnybalut
Post by sonnybalut » Mon Jan 03, 2022 11:15 pm
Here is my youtube demo, source in the description
https://www.youtube.com/watch?v=uu4slYGSQPE
Post by pythoncoder » Tue Jan 04, 2022 2:04 pm
Or use this MicroPython driver.
Thomas_G_S
Post by Thomas_G_S » Tue Jan 04, 2022 5:30 pm
Hello, thanks for getting back to me so quick. Pythoncoder, how would I install that library onto my board? I can't find it on Thonny and I don't know how to install libraries onto Pico without it.
I am now using CircuitPython Roberthh, thanks for the suggestion :)
Post by Roberthh » Tue Jan 04, 2022 6:44 pm
I cannot say that I recommend to use CircuitPython. My preference is MicroPython. But everyone has to go for her or his choice, and at least the best part of CircuitPyhton is the MicroPython core.
Thomas_G_S
Post by Thomas_G_S » Tue Jan 04, 2022 8:09 pm
Ok, I'll try them both out. Thanks! Btw, how would I install a library onto Pico that isn't on Thonny?
Post by Roberthh » Tue Jan 04, 2022 8:18 pm
Just copy the Python script(s) to the board, either to the top level dir or to /lib. For copying, you can use mpremote, rshell, Thonny, ...
Thomas_G_S
Post by Thomas_G_S » Tue Jan 04, 2022 8:47 pm
Ok, I've done that. I'm now running the test code and I'm getting the following error message:
File "<stdin>", line 13, in <module>
NameError: name 'BNO055' isn't defined
I'm using the library that pythoncoder posted earlier:
https://github.com/micropython-IMU/micropython-bno055
Post by Roberthh » Tue Jan 04, 2022 8:53 pm
Did you copy both bno055.py and bno055_base.py?
As first step, I would try bno055_test.py.
